Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Black cartridge printing very light!
Hello, kodak5300 printer. tried new cart., cleaning heads,and calib. color cart. works fine. very faint printing with black cart. inserted cart. numerous times.
can't be
time for a new printer already! ANY OTHER IDEAS ?
thanks ! mike
  • Anonymous Mar 27, 2009
    i have the 5300 black print very faint with lines in it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
I think its time to change the cartridge.
Posted on Dec 17, 2008
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
Black not printing properly. Sketchy, and faint. 2 new cartridges put in in 24 hours. Is my print head going? Color works fine
take a moist (from water) paper towel lightly rub the print heads and clean off the heads. hope that fixes it.
Dec 07, 2011 | Lexmark X2670 All-In-One Printer
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Installed new blk ink cart and others are all o.k. Will not print black at all - if I use the color button or try to print from the computer in color, words come out very light and other colors are not...
I assume that you inserted an new OEM black cartridge. If you are using aftermarket of refilled cartidges, change to an OEM cartridge.
- Press on the printer
- Press of and select
- Press of to choose , or
- Press
- The machine cleans the printerhead and goes back to the Ready screen when finished.
If you clean the head 5 times and things don't improve, the printer should be serviced at a printer service center.
If you are using aftermarket or refilled cartridges the ink is typically not up to manufacter specifications and can gum up the printheads.
Oct 04, 2010 | Brother Office Equipment & Supplies
I've got a Canon Pixma MP 500. Printing from my computer = faded print. Copying = blank page. Auto head align fails. Alarm light goes on. Have tried stop/reset button. How can I fix this?
It sounds like the print head on your printer is either clogged or not working.
You get faint print from your computer because the computer will use your color inks to get gray. When you copy, it only tries to use black and the black isn't printing at all.
Check your user's manual and it should show you how to clean the print head. Otherwise replace the print heads and you should be fine.
Thanks,
Pat
Aug 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Color suddenly stopped printing. black is printing fine.
Often ink printers will get clogged. This is especially the case if it sits idle for a while between uses, but can happen even with actively used printers. Try running the Dell printer's Head Cleaning Utility.
  • This is usually found by going to:
    Start > Control Panel > Printers and Faxes
  • Rightclick on your printer's icon
  • Choose Properties off the new menu
  • Click Maintenance
  • From there you should see the controls for Printhead Cleaning.
You should see an improvement after about 2-3 cleaning runs. This does use ink, but may be your best bet to resolve the issue.
Hope this helps,
Chris
Mar 23, 2009 | Dell Inkjet 720 Printer
Ricoh CL3500N not printing black?
Sounds like the Dev unit is about worn out. May also be a transfer issue.
Nov 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Wont print black but colors are fine,
Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Oct 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
289 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
