When inserting disc for back up, I receive the message, "Disc not formatted".
SOURCE: Compaq laptop cd rom not
is this a cd rom or burner, last time i had this problem, i just replaced the cd drive
SOURCE: My CD burner has stopped working. I get a message
Use a cd-lens cleaner for first step u will get this in computer shop.
u have wet and dry method choose one
or
if u are used to remove the cd-rom drive unscrew the cd-rom drive open it and clean the lens with a dampt cotton cloth then with a dry cotton cloth
SOURCE: Nothing happens when I insert the recovery disc
when it tells you to take out every disc, leave the recovery disc as it contains the files needed for it to recover your system to factory specs
SOURCE: Receive message "cannot install" after
Good day. If you're getting this kind of message there's a big possibility that your installer for hp office jet pro is already been damaged or got corrupted. What you can do is to download another driver to resolve the problem.
You can download this driver scanner so that once it is installed on your system if will automatically update or install the driver for your hp. Here's the link
http://drivers-driver.com/hp-officejet-pro-l7700
remember:
1. click download now
2. then install
3. then run the driver scanner and just follow the direction to fix the driver for your hp office jet
If you think that it didn't resolve your issue you can just uninstall it from your computer.
Hope this help you a bit. Have a great day.
