Question about Kenmore Dryers
Kenmore model 110.63932102 Dryer will run, however the timer does not move. We also have to play with the start button to get it to start some times. Opening the door does not break the cycle and as soon as you close it the dryer starts without having to restart
    Novelist:
  • 161 Answers
1. Opening the door does not break the cycle
The door switch needs to be replaced
2. the timer does not move
The timer should be replaced
3. Start button
This could be in the start button or at the motor
Posted on Dec 17, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore Front Load Dryer Model 97078712 Will Not Start I have a Kenmore Front Load dryer Model: 970787712 that wont start. If I hold the start button and jiggle the timer it starts. Is it correct to assume...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 21, 2011 | Kenmore Dryers
Dryer won't stay running after pushing the button.
that isn't the model number,it will start with 110. or 417.send the full model number and i can look up your dryer,most likely it's the even heat board or the motor relay but without the model number i can't look it up for you,these parts are in the top console,call the parts store give them the model number and they'll give you the right part or send it to me,let me know what you find
Jul 20, 2010 | Kenmore 63942 Dryer
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Dryer won't stop running
The hot wire runs through the start button as a bridge to complete the circuit until the motor centrifigal switch closes the circuit when running. Now if you manually start your dryer and the timer doesnt advance keeping the dryer on until you open the door or advance the timer manually then the timer is good but the motor to advance the cam is faulted. The second scenario is that the dryer is off when the door is open, but when you close the door the dryer starts. With the second scenario we have a closed circuit at all times. At this point you have either a stuck start button or the centrifigal switch is closed. Usually it is the start button on this model.
Sep 08, 2008 | Kenmore 67082 Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
119 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
