Question about Rockford Fosgate 800.2 Car Audio Amplifier
2008 Mitsubishi Lancer radio problems.
Dealership has yet to fix radio that intermitently cuts out and comes back on after ? minutes.
They have worked on this issue 6 times for approximately 20 hrs.
They said the harness is ok and replaced the radio.
I have received good advice from you guys but still need more information and recommendations to through at them.
Thanks,
Bob
  • 2 more comments
  • esimpson_gt Jan 04, 2009
    i have the same problem my car is a 09 lancer gt w/ the subwoofer
  • louislobster Feb 22, 2009
    my clock does not work on my lancer esate 56 plate also radio does any work fuses look fine
    hi i have problems with my clock dont work and my radio does not work looked at fuses all look ok
    any ideas
  • Marvin
    Marvin May 11, 2010
    this is a warranty issue let the dealer handle it.
  • 11 Answers
Check the connectors at every speaker make sure they are not earthing out
if there fine let me know and ill look more into it
also did u get the optional subwoofer ?
Posted on Jan 02, 2009
Help needed,I have a brand new lancer and I have a problem with the radio,somethimes the radio sound comes like with no trebile in it,cd is working ok,so it look like iit has a reciving problem.I change also the antena but still the same,
shawn.
Posted on Feb 24, 2010
    Problem Solver:
  • 6 Answers
There is a little ribbon wire that runs from the head unit to the hazard light button. If this comes out you will have these problems.
To fix your problem you must uninstall the stereo. Under the face above where the hazard button installs there is a little slot, you will see pins. You have to line it up right and its tough to push in. Dont crease the ribbon and Bing bang boom your done.
Posted on Dec 25, 2009
2 Suggested Answers
  • 599 Answers
SOURCE: 2008 Mitsubishi Lancer radio problems.
exactly what i meant to say.... you back charge the dealer immediately after successful repair is made and dont let anyone talk you into anything else...good luck and keep me informed !
Posted on Dec 08, 2008
How can blower motor be replaced?
2008 Mitsubishi Lancer HVAC Blower Motor Install How To ...
? 9:07
https://www.youtube.com/watch?v=PKZ2oIFHIdc
Apr 18, 2012 - Uploaded by LVzx2
All you will need is 15 minutes max, a short phillips head ... 2008 Mitsubishi Lancer HVAC Blower Motor Install How To .... If so , sounds its obviously not a direct replacement and or not for your car which could be the problem.
2008 Mitsubishi Outlander XLS Blower Issue? - YouTube
? 0:35
https://www.youtube.com/watch?v=rK81xZtc5Jk
Nov 14, 2012 - Uploaded by Jeff Mack
Intermittent noise that will occur during colder weather. ... 2008 Mitsubishi Lancer HVAC Blower Motor Install How To - Duration: 9:07. by LVzx2 21,758 views ... How To Replace 2003, 2004, 2005 & 2006 Mitsubishi Outlander ...
Dec 30, 2015 | Mitsubishi Outlander 08 2008
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Cd player not working
take it to a dealership
Oct 06, 2013 | 2008 Mitsubishi Lancer
2008 mitsubishi lancer
Its possible that you need to enter the unclock radio code. Check the owners manual.
Dec 30, 2012 | 2008 Mitsubishi Lancer
Help, I have a mitsubishi 2004 lancer and a SRS red light keeps coming on, what is this and what should I do.
SRS IS SUPPLEMENTAL RESTRAINT SYSTEM. THIS IS YOUR AIRBAG SYSTEM.WHEN YOU SEE SRS LIGHT FLASHING TAKE VECHICLE TO DEALERSHIP SEE WHAT CAUSING PROBLEM DONT TRY FIX AIRBAGS SYSTEM YOUR SELF LET DEALERSHIP FIX AIRBAGS DANGEROUS THEY CAN DEPLOY WHILE TRYING TO FIX SO LET PROFESSIONAL TECHNICIAN FIX.
Nov 05, 2011 | 2004 Mitsubishi Lancer
Regarding my 2009 Mitsubishi Lancer: Recently I took the radio out of my car and when I put it back in- It only functions when the headlight are on. Need to find the solution to fix it back to normal. Also...
befor you removed raido did you disable your anti theft if not then you need to have the anti theif reconfiged by a dealer, the reason it works with lights on is that its a over ride so if you raido gets theifted you will still be able to drive the car.
Aug 06, 2011 | 2008 Mitsubishi Lancer GTS CVT Sedan
I have a 2008 mitsubishi lancer, the am radio stopped work after 2 years does anyone know what the problem could be
Same problem with mine just today.
AM Radio not working anymore.
Any idea of what might it be ?
Nov 11, 2010 | 2008 Mitsubishi Lancer GTS CVT Sedan
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
Lancer IPod connect cord
I own a 2007 Eclipse.
You can purchase the cord from the dealership, with the instructions for the I-Pod cord. Not hard to install on the Eclipse, takes about 30 minutes to install. This is the only known place to get this I-Pod connector.
Jan 21, 2009 | 2008 Mitsubishi Lancer GTS CVT Sedan
Rockford Fosgate 800.2 Car Audio Amplifier Logo
1,530 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
