Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Ge profile buttom freezer cold refrigerator hot
Loud noise then the refrigerator stoprd working but the freezer is still working
    Novelist:
  • 161 Answers
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Posted on Dec 17, 2008
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
GE Profile Refrigerator freezer not working right & ice in refrig
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Noise
Most likely the fan is hitting some frost inside. Defrost the fridge by unplugging it for 24 hours and see if it helps.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | GE Profile Bottom-Freezer Refrigerator...
I have a ge profile refrigerator bottom drawer freezer... computer panel in back makes a loud clicking sound
Just common noise for GE refrigerators. As long as it does its job ur in good shape. Lack of adequate insulation to block out noise is one of GE's weaknesses. BB
Dec 15, 2009 | GE Refrigerators
I have a GE Profile PSC23. Everything works fine
I fixed it myself. After poking around the freezer, I saw that the area around the tube that gets water for ice making was frozen - this is at the top of the freezer. So I used a hot spong to melt the ice and the noise went away. Everything is working fine now.
Jun 17, 2009 | GE Refrigerators
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
266 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
