Candy Eclypsa CE10 washer dryer. Been told its either the pressure switch or pipe to it. I removed pipe and blew down it to clear but could be the wrong pipe. It seems to go down to a plastic chamber behind the drum but the switch at the other end is located between the two water inlets at the back. This switch boes not look like the one in a photo as it's square and small not round and about 50mm diameter. If I have the wrong pipe how can I find the right one Thanks for your help Colin
Comments:
Dec 18, 2008
- Thankyou for your reply. There are two switches on my machine I blew down both pipes and into the switches. This appears to have done the trick.
The pressure switch tube is only about 5mm in diameter so is easy to find, to be certain it is not blocked you need to remove it and check to see it is clear, and that the lower end where it is fixed is also clear, also make sure it is not punctured as this will result in loss of air pressure and stop the switch from working..
I assume it stops filling when you turn m/c off.
If it does not then you have a sticking water inlet valve.
plz rate my solution. Thanks.
Not emptying the water fully - need to be able to fix it myself and desperate to do some...
(More)
Not emptying the water fully - need to be able to fix it myself and desperate to do some washing!!!!!!! :)
Candy CNW156 is losing a lot of water and will not release door lock without mains power being...
(More)
Candy CNW156 is losing a lot of water and will not release door lock without mains power being turned off....is this simply overloading or something more sinister?! Door seals in good condition
candy cdb115 does a half wash then does not spin . stops then flashes start button and timer button...
(More)
candy cdb115 does a half wash then does not spin . stops then flashes start button and timer button at same time
Hi. I switched on my machine last night and it started on the cycle before it made kind of a popping...
(More)
Hi. I switched on my machine last night and it started on the cycle before it made kind of a popping noise and then I could smell burning/smoke. The machine won't work now but there is power to it and most of the lights are on the display so for delaying the wash the 3 hour and 6 hour are BOTH lit up etc. etc. Any ideas please? I did have my laptop plugged in at the same time and wondered whether it had caused the washer to blow a fuse? Many thanks :)
