Question about HP Officejet 6310 All-In-One InkJet Printer
Full Reset HP OfficeJet 6700 All-in-one Printer
For those wanting to perform a full, "out of the box" factory reset on an HP OfficeJet 6700 AIO Printer, here are the steps. 1. With the printer turned off, hold the power button for 5 seconds (you might see the indicator light on the power button blink once). Then let go. 2. Once the printer cycles on, press the "Home" button (top left, almost even with the top of the touchscreen panel and about 1 or 2 centimeters to the left of the touchscreen). Then press the "Return" button (bottom left, almost even with the bottom of the touchscreen panel and about 1 - 2 centimeters left of the touchscreen). Then press the Home button two more times. 3. You will see "Engineering Menu" pop up. Touch "Service Menu", then touch the right arrow button until you see "Resets Menu". Then, touch the right arrow button until you see "OOBE Reset". 4. You may see a grid background with a blue progress bar. Then press and hold the power button until the printer turns off. When you turn the printer back on, it will be in its "out of the box" state. This is helpful if you have a printer you need to return to the store, or if you are trying to sell one and don't want all of your information going to the new owner. Hope this helps.
  • Justin Shewell
    Justin Shewell Aug 08, 2012
    Sorry. Forgot to mention to press "Okay" after you see "Resets Menu" and then again after you see "OOBE Reset".
  • Tye Male
    Tye Male Mar 25, 2016
    All I can see is "Ink System Failure." I have tried everything. Removed and reinstalled printhead. HP cartridges are full. How do you get to the HOME screen?
2 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: I have been having trouble
!st thing that I do with intermittent fax problems is to call the phone carrier.
Tell them that you are having fax problems. Ask them to test your line. You could have a bad cable or noisy line.
Posted on Jul 10, 2011
I need the full factory reset procedure for my HP OfficeJet Pro 8500 A909N
Hi! this is Alex Walker call me +1(518)348-9393 i am expert to help you for this issue thank you
Aug 10, 2017 | Office Equipment & Supplies
My HP Officejet Pro L7650 printer says "Cannot
Hi
Firstly you should check if there is any covering on the ink nozzles
Did you try to allign the print catridges after you changed the same.
Take out the catridges and clean it with a piece of cloth again put it back and check
if still it doesn't work
If you have done it perform a semi full reset:-
Unplug the power cable at the back of the printer
Press and hold down the (#) and the (6) key together pplug in back the power cable
Leave the keys it should say on the screen semi-nvm reset if it doesn't says so its not done properly .. try to do it once again after that it should align the catridges automatically
This should solve your problem if not try with a different catridge
Aug 24, 2011 | HP Officejet Pro L7650 Printer
The relpacment printer locked up even before i hooked it up. to the lap top same problem as the first printer. it freezes and will not even turn off. hp officejet wireless 6500
Perform this reset
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Jul 11, 2010 | HP Officejet 6500 Wireless All-in-One...
Printer Stopped working and displaying code
To fix this issue, we have to perform the reset of the printer, perform the given below steps to perform the reset:
Apr 12, 2010 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam
Perform the steps in given below link to fix this issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125
If you still face the problem, perform the reset of the printer, here are the steps:
Apr 11, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 7410 is not responding in any way. No power; no life. Is there anything I can do to reset the printer without the printer getting any power?
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  1. Disconnect the power cord from the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
and it will reset the printer
Nov 20, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam
HI,
There might be an issue with the rollers of the printers , u can follow the link below and try to reset the printer to its factory defaults as well .
Perform a semi-full reset on the all-in-one by using # and 6 key combination. reset details are explained in the link.
link
Thanks
Jun 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6310 AiO reset steps
Two other resets are available.
#6 is a partial reset
#9 is a full reset
Jan 01, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
16,510 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
