Humidifiers Logo
Posted on Jul 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No/intermittent power to pressure switch
I've tested the system and currently have no power at the pressure switch. Before I got to this point I found a crack in the hose causing the switch to not operate properly. Fixed the hose, furnace ran fine for about 30 min, now I have no power to the ignition controls and have snaked it back up to the pressure switch which is now not getting power. This takes me up into the relay which I've never messed with. What next?
Paul Katynski
Level 3:
Master:
  • Master 575 Answers
  • Posted on Jul 16, 2017
Paul Katynski
Master
Level 3:
Master:
Answers
575
Questions
Helped
130530
Points
1806
I would check the relay to be certain that it's getting power. That pressure switch is only controlled by the relay controlled by the thermostat.
Honeywell he220 humidifier problems
Try removing the cover, and manually cycling on the controler switch? Does the solenoid click on, next to the humidifier (the unit with the water line running through it, with wires coming out of it)? If it does click on, is water running down the water pad? It doesn't necessarily drain water when it's working correctly. All of the water SHOULD be getting evaporated into the air return duct.
If it's clicking on, but no water is running out, you should check the water supply saddle valve and make sure it wasn't turned off during servicing.
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace. You may need to call a HVAC technician at that point, depending on your comfort level/skill level in that regard.
When you say the solenoid "stays hot" do you mean it's physically hot to the touch? Hotter than the water lines running into it?
If the solenoid is getting hot, it probably has a bad coil, and if you continue to operate it, you will probably burn up your DC power supply.
If you're getting voltage, you have water pressure, and the solenoid is still not opening, replace the solenoid.
I have no idea how to wire my Humidifier to the furnace! I am attempting to wire an Aprilaire Humidifier to an older furnace. The supplied wiring instructions are of no use to me because I have no terminal...
Hello, if the transformer you got with the humidifier is one that plugs into a receptacle than all you need is either a current sensing relay or sail switch. First connect one wire to transformer then connect to humidiistat then to either sail switch or current sensing relay and back to other terminal on transformer. if you use a sail switch then it will mount in the return air duct if you use a current sensing relay it will cradle the blower motors common wire. I will post a pic of both robhvac47_19.jpg current sensing relay
robhvac47_20.jpgSail switch
3helpful
How do I check whether my Lennox humidifier (made by Aprilaire) is getting current going to the valve solenoid? I've checked across the wires going into the valve and found no current. Thanks for your...
If you are not getting voltage to the solenoid valve then start at the transformer and check if you are getting 24 volts. If not then turn off power to the transformer and set your meter to continuity and check the transformer, if you dont have continuity the transformer is bad and must be replaced. If the transformer is good then check the wring to make sure the connections are tight and the humidistat, if that check out good then the current sensing relay/ sail switch is bad.
I have an aprilaire 550 that is not working. I found 2 wires coming from the humidity control, one goes to the solinoid, the other is hanging in mid-air. Where is this second wire supposed to be...
Hello, it depends on what type of setup you have with your humidifier. If you have a current sensing relay or sail switch than that wire connects there, howevere, if you have the humidifier that is powered by a furnace control board than that wire will connect to the transformer that the control board is providing with 120 volts with.
My aprilaire won't turn on, no power and it looks like all the conections are good, and power outlet is getting power. Any suggestions?
You need either a sail switch or current sensing relay to turn the humidifier on and off when the blower motor turns on. They both accomplish the same thing but in differant ways, a sail switch senses the airflow in the return air duct and a current sensing relay senses the current from the blower motor.
I have a model 560 Aprilaire humidifier thay doesn't work. I replaced the solonoid valve and it still doesn't work. What's my next move?
The system is 24 volt AC so start by checking the voltage from the transformer to make sure it is approximately 24 volts AC. The current will flow through the humidistat when continuity is made at the control as the humidistat senses that your house needs moisture. Disconnect the wires from the himidistat and set it to a high level, you should hear a click on the way up. With the 24 volt wires disconnected, check for continuity with a volt meter. If you don't have continuity replace it. Current also flows through an inductive sensor switch that hang on a wire from the blower. When the blower wire has current flowing through it, the switch senses that an closes makin the connection. With both wires disconnected from the 24 volts you can test for continuity when the blower is running. Overall, this is a continuous circle of wiring and is not directional like DC so think of the wiring a a big loop. The correct current has to flow through the transformer, through the humidistat, through the blower switch, through the solenoid completing the the circle before the solenoid will activate. Hope this helps.
3helpful
No response at all. test won't work, no clicks, please advise
Is a digital Humidistat? if is not, it should click at some point, make sure when you test that the furnace fan is running and heat is on, then check condensation pump is not full. Also check the 2 wirenuts under the humidifier, another thing to check will be for the presence of a current sensing relay, for this you gonna have to open the furnace blower compartment and look for a 2''x1'' box with a U metal clamp, hanging from one of the wires that feed the blower, sometimes, relocating this relay fix the problem, You can bypass this device for testing.
Furnace keeps running, no heat
The pressure switch is not allowing the igniter to heat up. Pressure switch is blocked or the flue is blocked. Take the draft fan off and inspect the flue. Also inspect the rubber hose connecting the fan and pressure switch make sure the ends are tight. Make sure the hose is clear and not restricted. And the pressure switch sometimes is position sensitive. I don't think it has been moved or anything. And very rarely do they go bad.
Aprilaire 760 w/ Auto-Trac quit
Have you changed the pad and cleaned it out ?
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
