Question about Microsoft Windows Server Standard 2003 for PC
RECOVER FIRST DNS
Sir how i can recover first dns host if it fail there is any method to recover first dns server?
    Problem Solver:
  • 6 Answers
Is there a running Domain Controller present? If so DNS info is often stored in Active Directory (A.D. Inegrated DNS Zone).  If this is the case you can just connect a server to the network, join the domian (verify DNS settings in TCI/IP config is pointing to Domain Controller) and then installm DNS from Add/Remove windows components.  Zone data should replicate from AD to new DNS server, to verify open DNS console and look for resource records relevent to the domain.
Posted on Dec 30, 2008
  • Nathan Mooney
    Nathan Mooney Dec 30, 2008
    Reinstalling DNS on a 2nd (member) server will trigger zone data replication to the new server if the zone file in DNS is stored in A.D. which is how it works by default, so, the question is... is there another server running server 2003 that is a member of the domiain? if so, install DNS in add/remove and you should be good.
What is DNS setup?
Domain Name System (DNS) is used in Transmission Control Protocol/Internet Protocol (TCP/IP) networks, such as the Internet, to locate computers and services through user-friendly names. When a user enters a DNS name in an application, DNS can resolve the name to other information associated with the name, such as an IP address. If your network is homogeneous (all hosts use the same operating system), and it uses a name resolution method other than DNS, you can continue to use that method without needing DNS. If your network is heterogeneous (the hosts use different operating systems), or it connects to the Internet, you will want to deploy DNS as the Internet consists of protocols that require DNS.
GuruAid.com
Jun 21, 2016 | Computers & Internet
How do i enter service mode
Use DHCP : Off Use BOOTP : Off Use RARP : Off Enable DNS Dynamic Update : On Use Zeroconf Function : On IP Address : 192.168.1.20 Subnet Mask : 255.255.255.0 Gateway Address : 192.168.1.1 LPD Printing : On IPP Printing : On IPP Printer URI : printer RAW Printing : On Raw Port Number : 9100 RAW Mode Bi-direction : Off FTP Printing : On Primary DNS Server Address : 0.0.0.0 Secondary DNS Server Address : 0.0.0.0 DNS Host Name : NB-17FB0000859B9287 DNS Domain Name : Multicast DNS Service Name : Canon iPF710 (9B9287)
Nov 21, 2012 | Canon imagePROGRAF IPF605 Printer
I cant update offsite dns setting
Your first step in setting up DNS for your domain is create some A records, or host records, that point to servers that you are hosting resources (like a website). So, for example, let's say you are hosting a website on a server with IP 13.54.33.21. You'll create an A record for 'www' (without the quotes) to point to 13.54.33.21. This way, when someone goes to www.buy2sale.co.in, they'll be sent to your web server.
I hope this helps!
Apr 01, 2009 | Microsoft Windows Server Standard 2003 for...
DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
Mar 24, 2009 | Microsoft Computers & Internet
DynDns update fails
I have given a ref. configuration for you. If you could provide me the debug results it would be great to help you.
set dns ddns
set dns ddns id 1 server-type dyndns clear-text
set dns ddns id 1 username USERNAME password PASSWORD
set dns ddns id 1 src-interface untrust host-name HOSTNAME.dyndns.org
set dns ddns enable
Then try exec dns ddns id 1
Oct 09, 2008 | Juniper Networks NetScreen-5GT Plus...
Hurricane h5200 modem/router
Hello jmazaredo,
Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
In other words edit your hosts tables (hosts file) with the entry (Example 1):
IPADDRESS FQDN ALIAS
192.168.10.2 somesystem.myhome.com. system
192.168.10.5 somesystem2.myhome.com. system2
This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
Once this is done if it works then try this setup:
1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
I hope this helps.
Thank you,
Shuttle83
Aug 14, 2008 | Computers & Internet
Why can't I access my ISP's resources, such as their mail and news servers on my RO318?
If the servers have simple names like 'mail' or 'news', the problem may be that the ISP's domain suffix is not being added to these names before DNS lookup. Add your ISP's domain suffix as Domain Name in the RO318's System menu. In addition, the ISP may be looking for a particular host name for your account, in which case you should enter the host name as the System Name in the RO318's System menu. Example: Consider the following account with the ISP "earthlink.net". 1. Host Name: C-223344-A 2. Domain Name: www.earthlink.net Mail Server mail Although the ISP lists the name of their mail server as 'mail', the fully expanded name is actually: mail.earthlink.net If the ISP automatically provides the domain suffix to your router, the router will append the domain suffix to DNS requests. If not, you can try one of these methods: 1. In each application (such as mail client or news reader), list the fully expanded server name, 2. Manually configure DNS parameters in the network settings of each of your PCs, and enter the domain suffix manually.
Feb 19, 2006 | NetGear RO318 Router
Microsoft Windows Server Standard 2003 for PC Logo
227 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
