Question about Karcher K 5.85 M Electric Pressure Washer
The soap dispenser with my Karcher 2400 psi and honda engine does not work.
5 Suggested Answers
  • 3 Answers
SOURCE: Karcher 2400 psi blaster When you
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Posted on Sep 17, 2008
  • 40 Answers
SOURCE: Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Posted on Aug 23, 2009
Testimonial: "Sounds good! I'll check it out and let you know. Thanks!"
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Karcher K2.19R unit will not dispense soap. Tried to blow out soap line with air compressor, but small clear hose just kept popping off! Unit sat for a couple of years, but rest of operation, water...
Sounds like it has been left with detergent in the pump and it has dried out and clogged. Always run fresh water through the detergent pump after use.
You will need to take the detergent pump apart or you may be lucky with water flushing through it.
Jan 19, 2018 | Karcher FactoryReconditioned K219R 1400...
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
How to use soap dispenser on Karcher K2.87 power washer
Also, be sure the cap is turned to the direction that lets the soap in. It has a gradation on it and if it is turned all the way to the smallest (cap fully closed) very little soap will be injected into the stream.
Apr 18, 2010 | Karcher Garden
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Need throttle sping help
Take spring to local harware or home improvement store (Ace, Lowes, Home Depot, etc.) and get a similar spring.
Jun 07, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even...
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
115 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
