Question about HP Color LaserJet 3500 Printer
Very Light Printer on HP Color LaserJet 3500
I change the transfer kit in my HP Color LaserJet 3500.
I used an HP OEM transfer kit and followed the instructions provided by HP.
Now the print is very faint, almost can see the printing.
Please help.
    Novelist:
  • 125 Answers
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Posted on Jan 10, 2009
How do you reset an hp 3500 color laser jet printer?
follow the steps :
  1. Press MENU to enter the MENUS .
  2. Press c00047416.gif (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press c00047417.gif (Select) to select CONFIGURE DEVICE .
  4. Press c00047416.gif (Down arrow) to highlight RESETS .
  5. Press c00047417.gif (Select) to select RESETS .
  6. Press c00047416.gif (Down arrow) to highlight RESET SUPPLIES .
  7. Press c00047417.gif (Select) to select RESET SUPPLIES .
  8. Press c00047416.gif (Down arrow) to highlight NEW TRANSFER KIT .
  9. Press c00047417.gif (Select) to select NEW TRANSFER KIT .
  10. Press c00047416.gif (Down arrow) to highlight YES .
  11. Press c00047417.gif (Select) to select YES . The transfer unit count is reset and the printer is ready to use.
Mohamed Hejazi
Afaqnama-LIbya
ipg@hplibya.com
Feb 27, 2013 | HP Color LaserJet 3500 Printer
Hi i have a problem with printer hp color laserjet 3500.my printer is error sms "printer error 59.99".what is a problem?
An error occurred in the secondary transfer
engaging mechanism.
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
Feb 23, 2011 | HP Color LaserJet 3500 Printer
Asking to replace transfer kit - old printer is this necessary? Can it be over ridden?
You can not over ride it. You can keep on printer till the printout gets bad. Then you will have to replace the transfer kit.
Gerrit Jan
Nov 11, 2009 | HP Color LaserJet 3500 Printer
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
Hope this works for you
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
Hp laserjet 3500 transfer kit
Hit the check botton on the control panel for the printer. Scroll down to "Configure Device" and hit the check button. Scroll down to "Resets" and hit the check button. Scroll to "Reset Supplies" and hit the check button. Scroll to "New Transfer Kit" and hit the check button. Scroll to "yes" and hit the check button.
Hit the return button (next to check button) until back at ready again. Transfer belt count should be reset now.
To make sure, from the info menu, scroll down to "print suply stus page" and hit the check button. Transfer belt should read as 100% now.
DON'T WORRY IF IT TAKES MORE THAN ONCE FOR IT TO TAKE. WE'VE SEEN IT TAKE 2 OR 3 TIMES OF REPEATING THE PROCESS (for no good reason) BEFORE THE MACHINE RESETS THE COUNT.
Aug 25, 2008 | HP Color LaserJet 3500 Printer
Hp inkjet 3500 prints red as yellow
how do i get the printer to read that i have put in a new transfer kit.
May 06, 2008 | HP Color LaserJet 3500 Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 3500 Printer Logo
361 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
