It works and i watch bbc but when i turn on my computer there is no icon in the tray.i do not turn it off so cannot understand why its not there.
The steps are a little different depending on which operating system that you are using. If you select the system tray or right-click it, you should get an option to 'Customize' system notification icons. You can then choose the options to hide or show various icons in the system tray.
SOURCE: 30 Jan Our Expat Shield
Hi
Unfortuantely no soultion but exactly the same has happened to me, any ideas welcome.
SOURCE: Why does expat shield no longer work in order to
Usually what has happened is that the Beeb blocks the ip#'s that anchor uses. Anchor then does a change and it shows up as ip#'s outside of that range and it works again. Until the next time.
I think the longest I have had anchor down was a bit over two weeks. Usually it is off for a day or so every few weeks. Just keep trying Anchor is are pretty good at getting it working again quickly.
Testimonial: "Thank you. I hope so. It is the only cultural satisfaction I get ;)"
SOURCE: Love expat shield. BBC iplayer
Hi there !
You need to upgrade the flash player you are using because the website does not recognized it anymore or it needs higher version of flash player installed in your computer. I have same problem this before and it works.
I am sure it will solve your problem.
