Question about Vacuums
The rolling part on the beater bar isnt rolling
Could be a bad bearing in the brushroll or the drive belt is broken
Posted on Dec 22, 2008
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
Roller will not turn
Conmaur102:
I don't know what type of vacuum you have, but you should check the drive belt to see if it is damaged. Remove the sole plate (at the bottom of the head) and remove the belt and roller (called the beater bar). check the bearings at each end of the beater bar (they must roll easily and smoothly). If they are bound up, pull them off of the ends of the beater bar and remove the hair, strings, and fibers wound around the end of the beater bar. Lubricate the bearings with light machine oil, and spin them by hand until they spin freely. Reinstall the belt and beater bar, and reinstall the sole plate. While you are at it... check the hose and head to make sure they are not clogged.
Jan 06, 2013 | Vacuums
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I dissassemble the beater bar?
It's fixable if you don't wait too long. Dirt and hair get under the end caps of the brush roll causing friction which causes heat which can damage the vacuum nozzle housing. If the housing isn't damaged you may just need a new brush roll and new belt.
Jun 18, 2017 | Bissell Upright Vacuum - The Pet Hair...
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar stalls
Sounds like the belt to the bar isnt turning properly or could be clogged up with dust or need replacing.
Either way youll need to open up the sole plate and check the condition of the belt by the rolling brush bar. Also check the condition of the brush bar to see if it isn't clogged up with general dirt and hair.
Apr 19, 2008 | Hoover U5753-900 WindTunnel Bagless...
Beater bar
You may have a bad switch, one part of it is not turning on the brush roll motor. It could also be the brush roll motor.
Feb 08, 2008 | Clarke CombiVac 12 Bagged Upright Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
172 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
