Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox 9P6040c101-- where do i find a Tech Manual???
In need of a tech manual to adjust the convergance
  • Philips Master
  • 3,459 Answers
Www.magnavoxhelp.com has manuals.
Posted on Jun 24, 2008
The two resistor 8ohm 2w has blow for the green convergence adjustement
if its a philips or magnavox the protection resistors should be 1.8 ohm and 1/2 watt. They are in pairs and if white in the middle and open it means both convergence chips also need to be replaced.
Let me know if you need help or advice.
SD TECH
Oct 01, 2011 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H Rear Projection Television convergence problems
You need to try to adjust it with the original remote in the TECH mode---you can save the adjustments there--
With the set on a video input with nothing connected:
hit the following buttons: 0 6 2 5 9 7 STATUS
The menu should appear with choices---green(do not adjust green) red to green, blue to green etc.
On that initial menu will be a item that says store or save. Depending on the remote you have once you select red to green (cursor on remote) a grid of lines should come up---on screen will be instruction--menu to adjust and or status to navigate.
When you have the red--to green adjusted hit the status button until it takes you back to the menu where Store or save is listed and right cursor on it.
This will store the adjustments.
Go back by selecting blue to green and adjust that also and when done go back and save it.
Turn the set off to exit the service mode and see what you have---IF THE SET DOES NOT RETAIN these adjustments made in the Tech menu something is wrong with its DCU--digital convergence unit---that stores the adjustments.
Let me know if you have questions as I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
I just replaced convergence chips on my 51 inch magnavox and it looks good, but i have to keep adjusting it every time i turn it on.
If you are adjusting the convergence in the customer menu you will have this problem.
What is model number of the Magnavox and do you have the original remote working for it?
There is a TECH menu for adjusting the convergence all over the screen--part of this is when you adjust there--you hit a couple of buttons and it SAVES the adjustments into the set's memory.
If you have the original remote I can tell you how to enter this mode and save the adjustments---The customer mode will usually give ok results but the TECH should give lasting adjustments.
Let me know and I will tell you how to get in etc.
If this information helps you rate this solution as I do this here for free---I am here to help people.
SD TECH
Nov 05, 2009 | Toshiba 53H71 53 in. Rear Projection...
Concave comvergence problem i believe
Unless you can solder and use a meter then yes you need to call a tech, this repair should run somewhere from $300-$500. Let me know if you need more info
Tim
Sep 09, 2008 | Sony KP-51WS510 51" Rear Projection...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Projection Convergence
Sounds like youre going to need the service manual, that will give you the proper technique and proceedures to check the various voltages and what not to find out exactly what your problem is. I am enclosing a link where you can purchase the service n=manual for your set for 12.99. They will even email it to you if you return to the site after purchase, click on the contact them link and provide your email. They also offer free tech support with the purchase of any manual they include instructions for support with the manual. Hope this helps. heres the link. http://servicemanuals.vstore.ca/
Jan 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence off on PT-47WX49E
If it's really bad and happened all at once, your convergence amps have failed would need to be replaced before you could correct the issue with an adjustment.
May 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Magnavox Projection Tv Problems!!!!!!!!
This is why if you don't know what you are doing in a tech menu, exit it! You will have to go through and do a full convergence alignment now. It isn't that hard but, not that easy.
Mar 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
TV screen problems
You will most likely need to have the convergence circuit repaired. Not an uncommon failure with CRT projection televisions. Go into your menus first and check the convergence settings and see what happens.
Mar 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
