Question about Watches
I have an Oakley Saddleback watch that will run flawlessly for a few hours then the second hand start to get erratic,,(click forward a couple seconds then backward a couple seconds) any ideas? Thx, Jim T
  • 2,334 Answers
You have tiny dirt particles in gear train or one of the gear wheel teeth is damaged. As a result of this the seconds hand is behaving erraticly when the damaged point on wheel reach the junction point with another gear wheel.
There is nothing you can do yourself. Find the nearest watchmsker and ask to overhaul your watch.
Posted on Dec 18, 2008
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Can the independent 12 hour hand be set and if so how?
You need to watch this video its given how to set time in Rolex watch's :
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
Stopping after 12 or 24 hours
Read your manual carefully and you will notice that the big, tall seconds hand is part of chronograph function. So, by pushing upper button you are actually engaging chronograph. This puts more strain on movement gears and consumes more battery power. When your watch is in normal timekeeping mode, the small seconds hand is counting seconds, not the big one which should be steady pointed at 12. I would recommend to put a new battery in your watch, reset it and start using it as described in users manual. You can download users manual here: http://www.oakley.com/customer-care/support/watches
Rate me, plz.
Jan 10, 2010 | Oakley Detonator OAK0530 Wrist Watch
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
My stopwatch resets to the 7 instead of the 12. Can you help
On most watches all you have to do is pull the crown to position 2 (the last) and depress pusher A (on the top). The second hand should advance in 1 second intervals. Keep pushing the A pusher until the second hand lines up with 12 hour marker. Push the crown back in and your done!
Apr 11, 2009 | Oakley Detonator OAK0530 Wrist Watch
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
Problem with second hand
I need to know what type of oakley is this .. i mean what model .. because they have different specifications..
Dec 26, 2006 | Oakley GMT OAK0531 Wrist Watch
Watches Logo
406 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
