U-verse and my linksys router
We talked yesterday, you said that the ethernet cable was to be plugged into the Lan port. The internet port on the router is the WAN, isn't it???? The internet port is the only one I can even obtain any internet connection with. Am I missing something. My Wii started to get an internet connection with this setup, but it stopped immediately. Everything else I followed like you said....... Have I done something wrong????
SkinWill
  • 148 Answers
SOURCE: Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Posted on May 01, 2008
  • 53 Answers
SOURCE: vpn
this is not so much a soloution but an idea!
from memory the netopia devices allow you to configure a dmz device by IP or MAC address.
I have had to do something similar but with a buffalo unit instead of your linksys. I ended up having to place the buffalo unitin into a dmz created on the netopia unit. before VPN tunnles were formed correctly.
Posted on Nov 06, 2008
Happy2Help
  • 59 Answers
SOURCE: Installing a linksys router with a u-verse RG.
Hi sgolob48,
First, make sure that the wireless network capability ofthe U-Verse RG is diabled (since you're using the Linksys for that purpose).
Second, make sure the ethernet cabel from the back of the RG connects to an LAN port on the Linksys (NOT the Linksys's WAN port).
Finally,disable the DHCP feature on the Linksys (since DHCP should be active on the U-VerseRG). Here's how:
1) Install the Linksys software on your computer and open your internet browser.
2) Type the URL 192.168.1.1 (default for Linksys access ponts).
3) You'll be asked to enter a username and password. The default is username "admin" and password either "admin" or [blank].
4) Once you've logged in, scroll down on the basic settings page (the one that loads automatically) to where it says Network Address Server Settings (DHCP). Click the radio button next to Disable, then click Save Settings at the bottom.
What you've basically done is make the Linksys another computer in your network, and the one that others will connect to the RG through.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
dante777
  • 623 Answers
SOURCE: Linksys And Vonage Setup Through Comcast
I will try to make this as clear as possible, but if you have nay questions, please come back here and let me know.
You will need 4 things: 1 Surfboard Modem, Wrt54G, vonage router, computer. Put them next to each other without having plugged in anything ( no ethernet, no power cable!). Make sure that the WRT54G router is back to default settings by pressing the reset button on the back of the router for 10 seconds.
  1. Connect the power cable to the Modem. Power light on?
  2. If yes, connect the coax cable from the wall to the modem. (The one that looks like a TV cable)
  3. Connect the power cable to the router and wait until the power light is on steady.
  4. Connect your modem to the router. Plug an ethernet cable first into the modem and THEN into the WAN port (the label says "Internet") of the router.
  5. Plug an ethernet cable into one of the router LAN ports and connect it to your computer.
  6. Power on the computer.
  7. Open the Control panel and the Network Connections applet.
  8. You should see something called "Local Area Connection".
  9. Double-click on it and click the Properties button.
  10. Double-click on "Internet Protocol (TCP/IP)" and make sure both radio buttons are set to "Obtain...automatically".
  11. Close all Windows by clicking "OK".(The second one takes a moment, because it applies the settings.)
  12. In the open window choose the Support tab and you should see your IP address, your Default Gateway (192.168.1.1) and your DHCP server (192.168.1.1)
  13. Open Internet Explorer and type "192.168.1.1" in the address bar.
  14. If you have reset your router to factory defaults, leave the username blank and type "admin" in the password field.
  15. On the first page (Setup), you should set the Internet Connection Type to "DHCP", unless you get a static IP from comcast (which i doubt).
  16. Go to the Wireless tab and ensure that wireless is enabled.
  17. Go to the "Security Tab - Wireless Security" and ensure that NO security is enabled for now.
  18. Open a new browser window and see if you can open a web page. Use an address that is unlikely to be in cache - try "http;//www.mit.edu" or so.
  19. Close your browser for now and come back here later to setup your wireless security etc.
  20. Now power on your vonage router and wait until the power light comes on steadily.
  21. Connect an ethernet cable from a LAN port of the router to the WAN port of the vonage router. (Plug it into the router first!)
  22. The vonage device should blink and establish a connection (Internet light is steady on). This might take a moment, because the device is downloading the newest firmware as well.
  23. Once the vonage router is on and the lights are steady (you didn't say which vonage device you have, so I can't tell how many lights there are), plug normal telephone ( not a wireless one) into the vonage router and see if you can get a call signal.
  24. If you were successful - sit back for a moment, enjoy the triumph and treat yourself with a nice drink!
There are a couple of things you still have to do, but the main thing is done.
  1. Make sure that you can access the internet from your wireless laptop before you start changing settings.
  2. Get a manual for the router here.
  3. Go back to your router's web page and set up wireless security (don't use WEP - that is not secure enough)
  4. You will have to setup QoS (Quality of Service), in order to prioritize your VOIP traffic, so calls go through clear even when you are surfing/downloading.
  5. You can setup QoS via IP or MAC address. Use your vonage router's MAC address (you'll find that on the bottom sticker), because it creates less overhead.
  6. If you plug in anything else into your vonage router, it might be on a different subnet and might not be able to communicate with your other computers (vonage router often use 192.168.15.x as their IP address)
  7. Once you're up and running and feel familiar with the settings for your router, I would change to a different firmware, because QoS is a crucial point for VOIP and I never was really satisfied with the Linksys firmware. I use tomato, for the simple reason that I was afraid of other more complicated firmware and you can always go back to Linksys, of you don't like it.
So...my fingers are bleeding now, but I hope this helped you out.
If so, please come back and let me know. Others might have a similar question.
If not, just tell me where you got stuck and we will go from there. According to the movie 'Galaxy Quest':
"Never give up, never surrender!"
Posted on Jan 04, 2009
  • 30 Answers
SOURCE: error 321 'ethernet not connected' on LINKSYS WRT54GS
Dont go with the error , i came across such instances on a few occasions while users were installing it from CD . (Sounds lamme?right)
Try doing the set up manually , by accessing the web Gui of router .
***FOLLOW THIS********
The GS comes set to 192.168.1.1 as its factory default and with its built-in DHCP server enabled. So all you'll need to do is plug in a client that's set to obtain its IP address information automatically, maybe do a DHCP release / renew (or reboot your client computer), and enter the default password into the login box that pops up. If all goes well, you'll get the main Setup screen.
The Internet Configuration Type selector automatically refreshes the browser screen to present settings appropriate to the choices of Automatic Configuration - DHCP, Static IP, PPPoE, PPTP and Heartbeat Signal (for Australian users) Internet connection types.
MAC address cloning gets its own page in the Setup section, as does setting up either dynamic DNS service from dynDNS.org or TZO, setting up static routes or disabling NAT features and converting the GS to a non-NAT router.
The interface is generally quick, with quick mini-reboots needed to get the changes you make on each page to take. Multiple admin logins are allowed, with no warning given when two or more admins log on. Once you're logged in, there's no idle timeout, and you just need to remember to quit your browser when you're done, because there's no logout button.
Enabling Remote Management for the first time still pops up a message telling you to change the router's default password and you can now enable secure (HTTPS) admin access. You can also change the default remote admin port from 8080, but can't restrict access by IP address or domain. Also of note is that you can't reboot the GS from the Admin interface.
Let me know if you require any more assistance.
Posted on Apr 19, 2009
I dont know where the end of the blue cord goes
Hi !
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Thanks.
Mongkey
"Understanding explains better..."
Jan 21, 2011 | Linksys WRT160N Wireless Router
Xbox and laptop cant connect at the same time
your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
Aug 19, 2017 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Ethernet cable 'splitter': Works on AT@T 'light' modem but not on cable modem. Are splitters speed sensitive
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
Oct 25, 2009 | Linksys computers10: EtherFast Cable / DSL...
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Hi sgolob48,
Kind regards,
H2H
Dec 16, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
386 people viewed this question
Alun Cox
David Payne
David Payne
