Question about GE Profile Harmony DPGT750EC Electric Dryer
Same no heat no blowing
Hi i was wondering what you did to fix the dryer
  • 207 Answers
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Posted on Apr 16, 2009
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
Dryer only blows cold air out.how can i fix it.
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 17, 2011 | Candy CDC266 Dryer
My Kenmore 400 series dryer has stop blowing hot air to dry my clothes. It blows room temperature air therefore, my clothes don't dry in a timely manner. How do I fix this problem? Thanks,
Hi Most ahve the same problem, maybe the dryer vent is plugged up , pull unit out and unplug it , remove vent and clean , then with a tester check over heat sensors at rear of dryer , they knid of look like diodes with two wires going to them , you could also by pass them with a jumper wire , BUT JUST TO TEST THEM ONLY ! it could also be th eelement , but most times it is a sensor form over heating unit , both are very cheep to fix,
Jul 27, 2011 | Kenmore 400 6942 Dryer
Hi I have a Tricity Bendix TM320W and it only blows cold air is there anything i can do to fix it? Thanks
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 17, 2011 | Tricity Bendix TM310W Electric Dryer
Will not get hot. just blows cold air. was wondering how many heating eliments are in the dryer?
heatman101
Jun 30, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My frigidaire dryer is not blowing hot air. How do I fix it?
heatman101';
May 10, 2011 | Frigidaire Dryers
The dryer runs but produces no heat. After a little the machine stops running and the lights that indicate what part of the drying cycle the machine is in all blink simultaneously. I am wondering what the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer no heat blows cold air what s a common fix gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Why my dryer doesn't blow HOT air??? what can I do to fix it???
heatman101
Sep 23, 2010 | Frigidaire FER641FS Electric Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
134 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
