Question about D-Link AirPlus DI-524 Wireless Router
No signal Hi again, I just got my laptop back and tried to reconnect to my wireless network. It had great signal strength before now there is none. I did not move or add anything? I did unplug and plug the router back in but the most I could get was low (one bar). Any suggestion? Thanks again for your help. Sandymcc
  • 62 Answers
If this model has a antenna, check its connecting with the router. Try resetting the router. Also some labtops have a worse signal reception strenght when they are not plugged in, so try plugging it in if you havent already.
Posted on Mar 25, 2007
Windows vista laptop failing to connect to some wifi networks including my home one.
Open Network and Sharing Center, Manage Wireless Networks, Remove your Home one. Exit Network and Sharing Center. reboot machine, Try to reconnect to your home one. If that fails, Release and renew IP : http://www.cs.cmu.edu/~help/networking/IP_renew.html
Dec 11, 2012 | HP Computers & Internet
My hcl laptop with winxp shows very weak wireless signal strength at just 2 metre from the modem though other devices show complete signal strength. the device manager shows no problems with the hardware....
You can try this solution
  1. Right-click on the 'My Computer' icon on your computer and choose 'Properties'.
  2. Click on the 'Hardware' tab and then click on the 'Device Manager'.
  3. Now, find the 'Network Adapters' section and click on the little plus-sign to the left.
  4. Find your wireless network adapter and right-click on it and choose 'Properties'.
  5. This is where things will get different depending on the brand of your laptop and wireless card and which drivers you have installed. Browse through the different tabs and look for settings such as 'Power Management' or 'Transmit Power'. Adjust the settings to either disable the power management or increase the amount of power used by the network card.
  6. Now, test your wireless signal strength to see if you still have the same weak wireless signal you had before. The chances are that you will notice an increased wireless signal strength.
Jan 17, 2011 | Computers & Internet
I have the DIR-655. Poor coverage/Signal strength
What kind of construction surrounds your router? Weak signal indicates walls reducing signal strength. Try a repeater in weak areas.
Dec 30, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Acer 1690 intel 2200bg.wireless often, cannot get internet despite having "very good signal strength" and "status:connected"
Hi
If you have a good signal strength and the status shows connected then i would say you probably have some form of spyware, trojans or rootkit on the system.
I would take it to a reputable computer shop as although there is plenty of software out there which will remove this kind of stuff, it doesnt repair the damage that they do.
Taz
Nov 09, 2009 | Acer Aspire 5100 Notebook
Internet/network problems
Connecting the laptop to your network using a network cable, does this solve your Internet problems?
Does this works without the Internet connection dropping out?
If the wireless connection has a low signal, try positioning the wireless router or the laptop to get a better signal strength.
Also try reinstalling your wireless driver.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Wirless signal strength fades
it sound like to me that someone is logging on to your router set up your laptop with wep or wap with 128 bit enycription and let me know how that works
Mar 17, 2009 | Toshiba Satellite A105 Notebook
Signal showing but no connection (zoom 5590 x6)
Hi……there could be a number of reasons why you can’t connect. I’m assuming you have rebooted both laptop and router to see if this helps, so let’s move on to some basic troubleshooting steps to start with:
  1. Can you pick up the internet through a wired (Ethernet) connection between the laptop and the router? If so, this narrows the problem down to your wireless connection.
  2. Can you login to your router again, and check to see if MAC filtering has been enabled. To find this, go to Advanced Setup > MAC filtering. If the status is ‘enabled’, disable it, Save changes, and try to connect wirelessly again
  3. If MAC filtering is off, and you still can’t connect, go to ‘View Wireless Networks’ on your laptop: disconnect from your network, wait 30 seconds, and reconnect. When prompted, re-enter your network key very carefully. Can you connect now?
If you still can’t connect, please come back to Fixya, and let me/us know the operating system on your laptop. Good luck…
Jan 17, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Wireless network problem
You can try deleting the wireless profile previously saved on you laptop and try to reconnect and make sure you got all your wireless settings and security with you { SSID, WEP or WPA/PSK}. If that doesnt work than try to access your router's page and change your wireless setting to OPEN Wireless and  for you to view your wireless connection and try to reconnect. If everything fails than you can try reconfigurig your router and reconnect each again for you to have your presario connected too. This wont be a prob at all . I can walk you through with it if you want to as i need more info re your pc and router setting.
Keep me posted.
Cheers
Jun 24, 2008 | Compaq Presario 700 470024-192 Notebook
Wireless signal degredation
Disable and renable wireless card, even try unistalling the wireless card and reinstall it. update driver for wireless card. then if those fail, put pc next to router if signal still bad then card needs replaced. If your ISP didnt have you power off the router for 30 sec then do so.
Nov 18, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
D-Link AirPlus DI-524 Wireless Router Logo
113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
