Question about Lionel Cw 80 Transformer
Transformer doesn't shut off completely
I have a new Lionel set with a CW-80 transformer.  At first it worked fine.  Gradually it began behaving strangely.  More throttle was needed to get the train moving, train speed changed abruptly without any throttle change, the reverse function became erratic, and then the engine stopped moving.  It's not dead completely, lights and sounds still come on, but erratically.  The power to the track never shuts off completely like it used to.  Even at zero throttle, lights and sounds still come on.
Your help is greatly appreciated.  Thanks in advance.
SOURCE: My new Lionel CW-80 trans former stopped working
I did the same thing as brian-sw. Opened the unit, removed the old in-line fuse and added an external fuse holder to make it easier to replace in the future. Transformer is difficult to open unless you have the triangular security screw driver. Security bits can be purchase from Harbor Freight but you will need to adapt them to fit into the channels where the screws are recessed. It certaintly would have been nice if Lionel installed an external fuse or circuit breaker. Guess they didn't want to loose the repair business.
Posted on Dec 19, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: lionel CW - 80 transformer
Check out this link, I think it will help.
http://www.lionel.com/media/servicedocuments/71-4198-251.pdf
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: Can I use the cw-80 transformer on any Lionel
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Posted on Feb 10, 2011
  • 13 Answers
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
Posted on Nov 20, 2011
How to remove the red handle and how to get to the fuses
You can't. These transformers aren't user serviceable. You can thank the Federal Government for that. If you can find the special tool to remove the case, you'll be able to open the transformer. For service, contact Lionel customer service or take the transformer to a Lionel Service Center.
Aug 14, 2015 | Lionel Cw 80 Transformer
How do you open lionel transformer cw-80?
On the base of the transformer you will find 4 tamper proof screws that you will need to remove to open the case. A triangular blade screwdriver will be need to do this. Once removed the tamper proof screws can be replaced with self tapping screws.
Silverhill Tools ASDTR1 Triangle Screwdriver
Jul 16, 2014 | Lionel Cw 80 Transformer
My transformer did not work
The internal fuse is probably blown. Contact Lionel at Lionel.com for instructions on how to get a replacement.
Jan 20, 2014 | Lionel Cw 80 Transformer
Lionel cw-80 transformer blown voltage regulator i cant read the size can you help?
The voltage regulator is part LM78L05. You might want to check the two diodes are ok as well 'D1' & 'D2', sadly I can't see markings on them.
Dec 19, 2012 | Lionel Cw 80 Transformer
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
Feb 05, 2011 | Lionel Cw 80 Transformer
My lionel rw transformer won't run the train unless ithe speed control is turned 3/4 way up or better . Can this be fixed ?
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
Dec 25, 2010 | Lionel Cw 80 Transformer
WHISTLE STOPPED WORKING on CW-80
replace the button with a new one just remember which wire goes to which terminal. you will need a soldering iron and electronic solder to do this trick , also make sure you un plug the transformer. by any chance you got any n-scale trains you want to get rid of . If you do send me the info @ robert.e.kelsey.jr@gmail.com I'am a disabled veteran with little funds.
Nov 30, 2008 | Lionel Cw 80 Transformer
Lionel Cw 80 Transformer Logo
635 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
