Question about Casio G-Shock GW500A-1V Wrist Watch
Model & spring issue with an old Casio G-Shock...
Arthur,
Thank you so much for your help. I do have a follow up question. Before I put the metal cover plate back on there is a rubber shealth then goes on -would it be fair to say that the spring has to go thru a hole in the rubber in order to make contact witht the metal cover?
  • 2,334 Answers
Yes, definetely thru that rubber gasket, otherwise there will be no contact and no sound respectively.
Posted on Dec 19, 2008
Changing batteries on a Casio G-Shock Cockpit watch
yes. wrong battery possibly...
395/399 = SR927SW/SR927W
The 395 is a lower power output but same voltage (1.5v). The power spike of shorting might have caused a spike in the watch electronics.. make sure they are right polarity too. These batteries are not high current items, but maintain their voltage over the 5+ year lifespan. The S and SW are basically interchangable except for the higher amerage output.
Jan 03, 2015 | Casio G-Shock G511-1AV Wrist Watch
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Model & spring issue with an ol casio G-Shock when replacing batt
    This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
    Good luck
    Arthur
    Dec 13, 2008 | Casio DW290 1V Classic Alarm Chronograph...
    Loose spring popped out from behind....now I have no sound!
    this video will show you were the spring goes next to battery
    Jun 14, 2017 | Casio G-shock G2300B-1V
    Lost alarm & all Beeps on Casio G-Shock G3110 Wristwatch
    You probibly lost a little spring that goes into your movement that makes contact the curcit board and the back of your watch. It is VERY small and alot of people who change their own batteries don't even see it when they open their watch and it falla out . If I knew your address I would send you a couple. If you look at the back of yhe inside of your watch you will probibly see a hole with a LITTLE straight line comming off of it, that is where that spring goes. NOW you MAY not have grounded your watch, that could cause that to happen to. Open your watch and look at the back. You should see a AC marking. Take a tweezer or a metal object and touch the ac and the top of the battery.Then re-set your watch time. I'm hoping that is it, if not you need that spring.Let me know what happens, and if I can assit you with any other watch or jewelry problem.Also we at home are proud of you!!! Good Luck!!!
    Jul 09, 2008 | Casio G-Shock G3110-1V Wrist Watch
    Battery replacement for a G-shock.
    The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
    Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio G-Shock
    Check out this YouTube video.
    http://www.youtube.com/watch?v=ogCz2vjUKVg
    Feb 19, 2008 | Watches
    Setting time on Watch
    go to this website follow the instructions for finding your particular watch module located on the back of your watch and enter it in the space provided. This will lead you to a place where you can download your manual and learn how to set your particular watch. here is the link to follow and please leave feed back if it was helpful. http://world.casio.com/wat/download/en/manual/
    Jan 29, 2008 | Casio G-Shock G7100D-1V Wrist Watch
    Casio G-Shock GW500A-1V Wrist Watch Logo
    114 people viewed this question
    Top Casio Watches Experts
    Ansel Alberto
    Ansel Alberto
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
