Question about GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
GE side by side with ice and water in door
Ice maker working fine. Water freezes and can be unfrozen using hairdryer but refreezes.
  • hunko Jan 02, 2009
    They installed a heater (to remedy their poorly designed door) but it froze up too.
    New Friend:
We have the GE ESS25XGMB BB, and the freezer door actually freezes up (on the inside) with large masses of ice. About once a year, I have to take the door completely off and apart, leave the inside (plastic) panel in the sun to thaw and dry, and then replace all of the insulation upon putting it back together. Lately, the ice maker has been dumping water in the ice bucket, which clumps the ice, and then causes it run out onto the floor. I'm thinking it's time for a new non-GE refrigerator...
Posted on Aug 28, 2013
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Posted on Dec 17, 2008
  • Jason Asher Apr 24, 2014
    So, I'm back again. I believe I have fixed the issue with my water line freezing. On a seemingly unrelated incident, the ice maker began allowing water to overflow, into the ice bin, and then out the ice chute. At first, I thought it must be the timing of the ice maker, but our model didn't have an option to adjust this, so I replaced the ice maker. This did not fix the overflow issue. Next, I replaced the water valve assembly, and this fixed the overflow issue. Inadvertently, I have not had any issue with the door freezing up since replacing both items, and can assume the water valve had been causing our water line to freeze somehow. Something to try, as I got it on eBay, it was cheap, and pretty simple to install.
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Ice Maker
First, are you sure that's the problem? To clean the line, if that's it...simply shut it off, disconnect it from the fridge and run the water. How is the filter? Is there a defective switch involved? Do you hear a click? Is there door water? Is the float on the unit working?
Dec 17, 2007 | Whirlpool GS6NBEXR Side by Side...
GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
233 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
