Question about RCA RS2640 CD Shelf System
Home Stereo System
I have a problem with a stereo unit. It was gift for my Grandparents back in Christmas 2005. The speakers does not function when I turn on the radio or cd player, but I hear just buzzing when I crank it up. And the tape deck doesn't work too.
  • 62 Answers
Sounds like a internal error on the amp itself. Maybe it caught a surge, I had a stereo unit that got zapped by the way it was unplugged from the wall.
Posted on Mar 25, 2007
SOURCE:
How to setup my LHT854 to route my LG 42LN5300 TV through the speakers?
You probably need to be a bit clearer as to what you want. But the f (function) key on the unit allows you to change the input To ARC if you have it set up. If you switch off your TV /stereo using the TV remote only this should shut down both. When you turn it on again both should turn on with the sound routed through your stereo ( when you turn on you need to wait a short while while the stereo starts up)
Aug 12, 2014 | LG LHT854 Theater System
The two rear speakers in my car have no volume
The first question I have to ask is: Are they automotive speakers? Home stereo speakers are typically 8-ohm impedance whereas automotive speakers are typically 4-ohm. If you try to put home speakers in a car, your car stereo head unit may not may not have the power required to overcome the higher impedance. If that's not the case, check your wiring to the speakers (I assume this is an aftermarket system?). If there is nothing apparently wrong with the wiring, try connecting a couple of known good speakers to the wires. If they work, your existing speakers are bad. If they don't work, you probably have something wrong with your stereo head unit. Good luck.
Sep 22, 2013 | Laser Receiver Replacement
Why do only 2 speakers play in steroe mode
stereo mode is just that - stereo. Stereo is two speakers, front left and right only. If you want the other speakers to play, select a surround mode.
Jan 29, 2013 | RCA RT2380 Home Theatre System System
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
I have lost he remote for my Philips LX600 sound surround system . I need a code to . Can I use one for all remote to replace lost remote ?
For basic and advanced functions,I've had REALLY good luck with Philips Universal MULTI-FUNCTION remotes- Particularly the long slender silver multi-function models,and they will come with Philips functions pre-enabled-just be sure to get one w/the CORRESPONDING button for amp/receiver/stereo/stereo in-a-box,and check back of remote package to see if it operates Home Theater In a Box [HTIB] However,w/OneForAll remote,you would need to give the model # of the remote. Good Luck!
Dec 21, 2009 | Philips Home Cinema Amp + Speaker system...
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
I have a jvc home stereo model number CA-HXC6 i have had it for a few years its on protect mode and i cant get it off dont know how it cuts off
Turn off power, unplugg unit, very carefully check speaker wire connections making sure no wires are touching each other or the back of the unit same at speakers connections. Also check speakers. Blown drivers can short terminals internally. This is the most likely problem. Remove the short, unit will come back on
Dec 21, 2008 | Bose 901 VI Main / Stereo Speaker
Kenwood amplifier
A home stereo system is not complete without an amplifier which drives the speakers. A preamp cannot drive a speaker. Try to read the labels at the back of the system...if it reads speaker then that is the amplifier output. Would you mind giving us what model is your system?
Sep 18, 2008 | Audio Players & Recorders
Delphi Stereo
i think its bundled with other system! it will work only with certain devices
Dec 06, 2007 | RCA WSP155 Main / Stereo Speaker
RCA RS2640 CD Shelf System Logo
162 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
