Question about Whirlpool RBS245PDS Electric Single Oven
I have a GBS307 built-in oven stopped heating
I have a GBS307 built-in oven and twice when I've had it in self-cleaning mode it just stopped heating. The displays are fine and it even said it was pre-heating, but stayed cold. The first time the serviceman said it was some sensor, and is schd. to look at it again tomorrow. Is this a problem anyone else has had?
  • 1 more comment
  • Anonymous Dec 27, 2008
  • Anonymous Mar 15, 2009
    same issue
  • ugadawggirl Mar 15, 2009
    I also have a GBS307 model and went to pre-heat this morning. The timer timed down as if it was pre-heating, but when I went to open the door and place my pan inside, it was completely cool. Any advice would greatly appreciated.
  • 979 Answers
It has been a while since he was there. Did you have to replace a board? Hopefully, it is fixed.
Posted on Jan 30, 2009
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Thermador Ovens
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
heatman101
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2010 | Thermador SC302T Electric Double Oven
Excessive smoke comes out from oven when cooking
hmmm sounds a bit strange is there anything at the bottom of your oven that has been spilled on it even on the heating coils? (if electric) (if gas there could be a very serious problem with the oven that needs fixing right away!)
Dec 17, 2017 | GE 30" Built-In Single Electric Wall Oven...
I have a whirlpool gbs307 oven and after completing a self-clean cycle and wiping it clean after it cooled, it won't heat at all. Any ideas?
HI,
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
thank you,
vijay
Sep 29, 2009 | Whirlpool GBS307PR Electric Single Oven
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Oven not heating
heatman101
Nov 16, 2008 | Whirlpool SB160PEE Gas Single Oven
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Whirlpool RBS245PDS Electric Single Oven Logo
320 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
