Question about Jenn-Air JCD2389G Side by Side Refrigerator
Water Leak at Defrost Time on Jenn-Air JCD2389G Side by Side
My guess it's the drain plug - not sure where the plug is located.
About every 3 to 4 days will have Water in front of the freezer door.
    Novelist:
  • 161 Answers
On the freezer side take the bottom drawer out and look at the back wall. You may get a partical view of the bottom of the cooling coils and directly below is where the water will drip from these coils. You may need a light and get your head back there to see the drain hole but it's there. This drain area could be filled with ice so, a hair dryer will do wonders. A tube with a little air pressure can unclog the drain. Pour a little water down the drain to make sure it's unclogged. Check this area often as this problem will happen again.
Posted on Dec 17, 2008
Where's is the defrost drain for Jcd2389gt
Click Here=> Maytag JCD2389GTW Freezer Compartment is where you see the drain begin inside freezer and behind panel labeled location 20. The other end of defrost dran comes out below refrigerator and near condenser fan motor. How to clean a defrost drain Click HERE=> How to Fix Fridge Water Leak, Thanks Sea Breeze
Much more on this page=> Leaking Refrigerators!
May 05, 2012 | Jenn-Air JCD2389G Side by Side...
Water leaking from freezer, ice forming at bottom of freezer
Defrost drain at the bottom rear under panel is either iced up plugged or both.
Nov 23, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air side by side and the drain at the bottom of the freezer side keeps freezing up and the water ends up draining out the door onto my floor. I defrost the drain and it's ok for a couple...
You are going to have to get the drain good and clean. Take a turkey baser and force hot water down the drain until water flows freely. Once water is flowing freely mix water and baking soda and pour it down the drain. I hope this helps.
http://www.appliance-repair-it.com/Refrigerator-repair.html
Oct 21, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389ges has a sporadic water leak. I suspect that it is occurring during defrost. A clogged line? How do I access this to clean out?
Your plastic lines at the bottom left side of frig have dry rotted from the heat of the compressor. it will leak every time the water comes on to fill the internal tank. I had the same problem and I replaced mine with copper.
Oct 29, 2009 | Jenn-Air JCD2389G Side by Side...
I have water leaking on the floor due to a clogged defrost drain (probably) but I can't locate the drain on either side. Checked under the bottom compartments on both sides. Water is turned off and still...
You have to take everything out of the freezer side and remove back panel. There are 2 white hex screws around where the second shelf normally is. Top half (where fan is) comes off first, then bottom half comes off (it may be stuck if coils are frozen, let defrost a little). You will see stainless steel drain pan below coils. Also could be ice maker water supply or water chiller behind lower drawers on refridge side.
Jul 27, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
211 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
