Question about HP LaserJet 1010 Printer
Page stuck while printing page is stuck what to do
  • 62 Answers
If you can see the page and easily reach it just pull it out, and then press whatever the printer asks after the jam has been cleared. You can pretty much do whatever needs to be done to remove the paper, as long as it doesnt put any excessive force on the components.
Posted on Mar 25, 2007
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
HP 2200LaserJet prints a few pages, then gets stuck
You may have a recurrent paper jam. Use a strong light to examine the entire paper path. Even a tiny fragment of paper can cause the problem you describe
Jan 27, 2013 | HP LaserJet 2200D Printer
Test page prints each time it's turned on
Test pages are often printed by holding down one of the buttons on the printer. Make sure that none of the buttons are stuck. Look up in your printer manual which button is for test print and make sure it isn't stuck.
Aug 15, 2009 | HP PSC 1410 All-In-One InkJet Printer
Canon mp160 printer is printing blank pages after i put new cartridges in
This may sound silly, but I have myself made the mistake of inserting a new cartridge and not checking on the cartridge print head for a piece of sticky tape covering the print head. This tape is often stuck there by the manufacturer to prevent the ink from leaking out or drying up.
Check to make sure there is no tape stuck over the print head then check to make sure your printer driver is installed properly.
Try printing a test page to determine if the problem is related to the application from which you are printing or if the problem is printer related. To print a test page, go to your printers and faxes page from control panel and right-click on your printer icon and choose "properties".
Hope this info helps to solve your problem.
Regards,
Graemevm
Apr 22, 2009 | Office Equipment & Supplies
Paper stuck
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Konica Minolta magicolor 2300DL Laser...
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Won't print again
Printer won't prrint from PCto printer
Oct 24, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Paper does not come all the way through the printer
This is more of a workaround than a fix: I open up the front door and use the Face-Down Tray to collect all my printouts.
Aug 09, 2006 | NEC SuperScript 860 Laser Printer
HP LaserJet 1010 Printer Logo
70 people viewed this question
Clive
Clive
