Question about Singer Inspiration 4210 Mechanical Sewing Machine
Needle hits the plate, instead of going to the hole in the plate.
I think the plate has been shifted a litte
Maybe the tip of the needle is bent or needle not correctly in
Posted on Dec 18, 2008
The needle is hitting the needle plate (and breaking, of course) instead of going through the hole to the bobbin
I am wondering if it could be an issue with the type of needle you put in there. I am having trouble with a sewing machine tension and the store people told me that you have to use the manufacturer/ original style bobbin (it's engineered to fit the gadget 'Just so').
I know on my non-computerized Brother sewing machine, that I can change the needle position to L/M/R and I see it move when I move it left and right.
I guess you've probably checked all of the other settings on your machine?
Is the presser foot coming unscrewed?
Mar 03, 2014 | Brother PE770 Computerized Sewing Machine
Singer serger 14u
Sounds like your needle is hitting the needle plate instead of going through the tiny hole down to the bobbin. Try using the handwheel slowly and watch. Or perhaps the needle is hitting the bobbin case. Something has been knocked off the straight I think. Has your machine been dropped or dmamaged?
Oct 15, 2013 | Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Feb 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
How do I adjust the timing on my SINGER CG590C
If you have a zig-zag machine check to see if the needle is set to the correct position. If you are trying to zig-zag, be sure you have the wide holed throat plate on.
Jan 27, 2009 | Sewing Machines
The needle hits the bottom of the plate, instead of going to the hole in the plate. So, it seems that the plate was shifted a little. how can i get the plate to shift back to its normal position or to get...
Actually, first make sure you have the needle in properly... take it out, then replace it taking special care to hold it straight up and down. If that doesn't work, then the screws on your plate may be loose or one is missing, so manually shift the plate back to where it needs to be and tighten screws.
Dec 17, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Singer Inspiration 4210 Mechanical Sewing Machine Logo
173 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
