Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
I get a backup, but with a lot of error messages
I read the error log and it says, file not supported or internal error. I test my drive and it tests successfully. 99% of files get backed up but it would be nice to get a "successful backup message" or know why some files are skipped.
    Problem Solver:
  • 6 Answers
Microsoft has some hidden directory levels and files in VISTA and in XP that are visible only when the settings for the directories in which they exist are changed from the hidden setting.  It's tedious, but possible.  I assume, then, that what you were unable to copy to your backup are these hidden files.  They're placed that way as a default in the Windows install to protect the user from accidental "mistakes". Example:  Under "users", {name},AppData,Local,...
Posted on Dec 20, 2008
Error code 0x8078002A toshiba canvio
This is usually caused by how the hard drive is formatted. I.E, how the disk is broken up into chunks so the computer can easily read/write/organize data.
Seems like most of the time, the solution is to reformat the drive to use 4k PHYSICAL sectors, rather than the 4k logical sectors these drives are formatted to by default. Be warned that by formatting a drive, you lose all the data on that drive.
Aug 17, 2018 | Toshiba Computers & Internet
Tip
How to display Errors found and Repairs made by CHKDSK
<b> <p>How to display Errors found and Repairs made by the CHKDSK Command<br /></b> The Chkdsk command is used to verify the integrity of a file system and is capable of correcting discrepancies in system data files. This command has been with us since DOS days and has been modified by Microsoft as required to meet the requirements of new operating and file systems as they evolved. <br /> If you execute the Chkdsk command from a command prompt without using the F (fix) switch, Chkdsk runs in the read-only mode. As Chkdsk runs its tests on the drive, it displays the results of these tests on the monitor screen and the test results remain there for you to read until you close the CMD box.<br /> However there are several drawbacks to running Chkdsk in the read-only mode, especially on an active NTFS volume (usually C:) <br /> 1. Chkdsk cannot make any corrections to the drive while in the read-only mode.<br /> 2. If Chkdsk encounters more than minor errors, it will not complete all of its tests.<br /> 3. If you are running Chkdsk in the read-only mode on the active partition, Chkdsk frequently reports disk corruption and other file system errors which do not exist. This happens when the system modifies the disk during the Chkdsk testing sequence.<br /> Considering the above, there is little to be gained by running Chkdsk in the read-only mode.<br /> You need to run Chkdsk/F at the command prompt to test the drive and to correct any errors found.. As soon as you make this entry the system responds with:<br /> "The type of file system is NTFS. Cannot lock current drive."<br /> "Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N)."<br /> After you key in "Y" (followed by enter) and re-boot, the operating system starts to load and you are advised that a disk check has been scheduled and unless you cancel it, Chkdsk/F will start to run in a few seconds. (Actually the file being executed at this time is Autochk.exe). Chkdsk will run through its phases but it only displays the test results on the monitor screen for about 2 seconds before the screen clears and the operating system continues to load!<br /> If problems were found wiith the file system, you will not have time to read any messages regarding what they were or what actions were taken. If corrupted files and/or orphaned files/directories were detected you would most probably like to know about it and other problems found by Chkdsk. So how do you display the errors found and actions taken?<br /> The answer is that since running Chkdsk/F is a system event, the information is recorded in the System Event Log under application events. To read the log, Click on Start, Control Panel, Administrative Tools, Event Viewer and Application. Look for "Winlogon" in the Source column and double click on it. An Event Properties dialog box will open and display the log for you to read..<br /> Yavacotech.<br />
on Dec 09, 2010 | Computers & Internet
Tip
How to display Errors found and Repairs made CHKDSK
Yavacotech.
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Yahoo messenger error "this application has failed to start because the application configuration is incorrect"
Can you get the Chkdsk to run in the general Windows interface by following these instructions?
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Try it first by not checking either box (this will run it in a Read-only mode) to see if it flags any hard drive or file problems. If it does, restart it by ticking both boxes, and rerun it to allow it to attempt to fix any found problems.
Does your Command Prompt work from Safe Mode or from a Clean Boot?
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/default.aspx/kb/929135
Does it work if you test with another user, you may have to create one to test with?
Is System Restore and the System File Checker able to fix anything?
How to repair the operating system and how to restore the operating system configuration to an earlier point in time in Windows Vista (or 7)
http://support.microsoft.com/kb/936212/#appliesto
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program generates in Windows Vista
http://support.microsoft.com/kb/928228#appliesto
Have you tested for Malware? I see lots of recommendations here for programs like -
Malwarebytes' Anti-Malware
http://www.malwarebytes.org/products/malwarebytes_free
SuperAntispyware
http://superantispyware.com/
Source: http://answers.microsoft.com/en-us/windows/forum/windows_vista-windows_programs/yahoo-messinger-wont-start-it-says-the-application/a4f50587-af18-44c8-9157-5157e465a191
Dec 31, 2011 | Yahoo Messenger
I have an iomega lphd-up external drive it was working fine now it is saying that it needs to be fomated plugged in to several laptops i get the same message. i dont wanna lose the content. what can i do?
Try getting a live cd (such as the system rescue cd). Burn the .iso file to a disk, then boot from the CD by hitting a key at your BIOS menu (usually F1 or F9) to bring up the boot menu, and select CD. Once you've booted and you have your prompt, plug in your external drive and try the following commands:
fdisk -l (that will show you all the disks attached to your computer. Typically the first disk [internal] is sda, and the USB disk is sdb.) The thing to take note of here is the last column on the list that contains /dev/sdb#, it should say NTFS, or FAT32, or something like that.
fsck /dev/sdb1 (that will check the file system on the first partition on your external drive. If it comes back with an errory, try fsck.NTFS or fsck.FAT32, whatever the file system was in the first part.)
testdsk /dev/sdb (That will initiate a harddrive test that could find/fix errors with your drive).
If none of that works, plug in another drive to make a backup of your external. Take note that it's important to have free space on the SECOND (not broken) external that is EQUAL TO or GREATER than the amount of USED space on the broken drive.
Once the backup drive is plugged in, type mount /dev/sdc1 /mnt/backup (if that doesn't work or it says something about NTFS and read only, type umount /mnt/backup; ntfs-3g /dev/sdc1 /mnt/backup).
Finally, type mkdir /mnt/backup/SDB to make a directory to store the files.
Now with the second drive, try to mount it using the advice for sdc (although change /mnt/backup to /mnt/windows)
If it mounts, then type rsync -av --progress /mnt/windows /mnt/backup/SDB/ which will start copying all the files onto the backup drive. NOTE: This will cause a lot of text to scroll, and will take a long time!
Once that's finished, you can restart into windows and format your drive, then plug in the extra drive and copy everything back over.
Hopefully that helps!
Jul 20, 2011 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
My computer is running very slow. So I ran test of my Maxtor 6Y160M0 hard drive using the computer's "PC-Doctor" software. The 'linear' test failed, giving me an error code the instructions...
the drive is going bad
Try to format the Maxtor.
NOTE: obviously backup all important data to a removable drive or CD.
You will have to reinstall windows. so before doing this, make sure that you have the cd and Product key (usually on CD case).
Aug 09, 2008 | Computers & Internet
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
209 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
