If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
SOURCE: my laptop uses toshiba mk3265gsx
I suggest try to isolate the problem, try to check if its going to work to any other machine, see if the enclosure can properly supply power for the HDD, also check if the cable that comes with the enclosure is working, try different cable or try going to any computer local center and have them try your external HDD. Make sure you installed properly the HDD.
Hope It helps. =)
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
