Question about Car Audio & Video
Wiring a ford fiesta rear spoiler with brake Light
I am trying to connect a rear spoiler with integrated brake Light, but i don't know which coloured wires to connect to on the light cluster. The instructions i got with the spoiler are not sufficent.
Any help greatly appreciated.
  • 15,935 Answers
You will need a power and ground. The Ground can be any metal on the chassis... and the power will come from the wire that shows 12V when the brakes are applied.
Posted on Dec 22, 2008
Where is the brake light fuse on 2005 ford fiesta
That is in the owners manual. Go to the factory site and download the owners manual if you don't have one, it is free.
Oct 25, 2012 | 2005 Ford Fiesta 1.3
I have a Ford Fiesta 2007 1.4 TDCI. When I brake
Check the wiring harness. Sounds like it has come in contact with the break assembly and is shorting out. Look for exposed wiring where the cover has worn off coming in contact with the break. Tape all exposed wiring and be glad you haven't had a small fire.
Sep 17, 2009 | 2007 Ford Focus (3 Door) Hatchback
Radio wiring colours for fiesta 2000
if you are looking to put a new stero in the best thing to do is go to radio shack or the parts house and spend 5 or 10 dollars and get a wiring adapter. You can wire the thing in your house all the colors are the same and then you just walk out to your car plug it in and go. It is worth the money it is pretty cheap anyway.
May 24, 2009 | 1999 Ford Escort
I am scraping my M reg ford fiesta, radio is good
there should be a short section of wiring loom from the rear of the head unit to two connector blocks.These a usually universal from car to car, just take that from the fiesta and plug straight into peugot. Failing that you can buy them at most auto factors.
May 01, 2009 | Car Audio & Video
Rear spoiler on a 2005 equinox
Just took mine off. There are three 10mm bolts that gofrom inside the liftgate into the spoiler-one on each end of the spoiler, oneaccessible through the large hole in the center of the gate. There arealso three pegs (that you can't see) mounted on the spoiler just under theupper rear taillight. The pins plug into holes on the liftgate. There's one peg towards each end of the taillight, back towards the roof. There's one in the center of the spoiler, towards the window. They'retight and solidly their holes. There is no tape or glue-just bolts andpegs. You don't have to cut or drill anything. The only tools you'llneed are a 10mm socket, an extension, and a ratchet.
I discovered the pegs when I got fed up trying to figure out what was holdingit on, said to heck with it, I know I may break something, but I've got to fixwhat's broke and gave it good, firm lift up from the window edge. Lo andbehold, it popped off--much to my relief. I fixed what I needed to(stopping the spoiler from vibrating madly as I rode down the road), and justpopped and bolted it back on. You don't need any kind of kit toreinstall it.
Once it's off, you can access the taillight and sprayer. Noproblem.
My only concern now is what I would have had to do if I'd broken one of thepegs. Thankfully, I didn't have to do that, so if you do, I can'thelp. It's easier than it looks, but it is scary
Apr 20, 2009 | 2005 Chevrolet Equinox
How do you replace the brake light on the rear spoiler on a 2001 Hyundai Accent?
This is the Spoiler Dude. The spoiler light is attached with screws to the spoiler. You must remove the screws and then the spoiler light will come away from the spoiler. Clip the two wires ( Black & Red ). Attached the new spoiler light ( I can get that for you) with a sleeve. Test the new light with the brake pedal depressed. Screw in the new light and that is it. If you have any questions.
Call Spoiler Dude Paul
719-661-8600
www.spoilerdudepaul@gmail.com
Apr 20, 2009 | 2001 Hyundai Accent
Original plugs cut off do you know which colour wire is what?
ok this is what you can do check this website: "the12volt.com"look for vehicle wiring and even though it does not have fiesta i think that the wiring for the 1997 ford escort is the same.Try that out it should be some help for you.
Mar 30, 2009 | Car Audio & Video
2005 Lincoln Ls 3rd Brake Light Wiring
The best way to wire a third brake light is to run the wire directly from the brake light switch on the side of the steering colum to the light. You will need a test light to find out what wire lights up when you push the brake pedal. Then you can splice into it when you run your wire to the rear light.
Jan 01, 2009 | Lincoln LS Cars & Trucks
Nissan Maxima 91 Rear Spoiler brake light broken
some of this cars have 1 fuse per side make sure to chek all the fuses some cars have more than one fuse box
May 29, 2008 | 1991 Nissan Maxima
Car Audio & Video Logo
347 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
