I am wanting to buy a yamaha vstar 250, however due to left leg problem I have a problem shifting up like reg shifters. I like to bike but Im trying to find out if a heel and toe shifter is available to buy and put on this type bike.
SOURCE: heal toe shifter for 2002 yamaha 650 v star custom
as far as i know its just a stratght swap, as far as parts go just google it online. probably get one on e-bay at a good price
SOURCE: heel-toe shifter does not return to center
i would check all ur splines on the shift arm and the shaft on the trany take out the bolts clean and re tourqe if the shaft out of the trany is not returning the yes u have broke the internal spring in the trans not a fun fix hope this helps
SOURCE: how do I shift my 2007 v star classic. I never
toe down for first, half click heel for neutral, then heel shift for 2,3,4,5. toe down to down shift.
SOURCE: installing a heel toe shifter on a suzuki
Nothing external; it simply slips onto the splines of the shifter shaft. Since the Volusia became the C50 in '05, they have been stock, did a previous owner remove yours?
SOURCE: My 2006 Road King toe shifter is stripped. How do
If that's where your shifter is stripped, you're lucky. Usually, they strip back where the shifter rod connects to the shifter pawl shaft.
To replace the shaft at the shifter lever, just take the floor board off and the bolts that hold the shifter bracket on. Slide the bracket off the shaft and take the shifter rod off the shaft. No problem.
Good Luck
Steve
