Question about HTC Touch P3450 Smartphone
Htc touch camera doesnt work... did soft and hard reset n tried to start camera app. from windows folder but no response....help needed !
    Scholar:
  • 59 Answers
Among the many issues with the Touch, the camera is another. If a hard reset doesnt work, your device will need a new camera. If you have Sprint, this can be replaced at any service center for no charge if you have insurance and there is a part for immediate repair.
Just to confirm, when you do a hard reset make sure that you press and hold both of the softkeys while sticking the stylus in the reset hole until it asks to reset.
Posted on Dec 18, 2008
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
I have HTC touch and it keeps freezing up. as specially when I want to read or send message via sms or email
try cleaning up your inbox's and if that doesnt work soft rest the phone. it may be because of the amout of programs running on the phones memory making it slow eg the camera, games, maps etc you could open the task manger and see what programs are running then close them.
if nothing works try hard resetting the phone (will lose all data on main memory including installed programs)
Oct 16, 2009 | HTC Touch P3450 Smartphone
My htc touch viva is booting but not loading the os, only a blank screen with the top taskbar, tried hard reset but no luck. was working fine until i soft reset after installing an app.
Actually I only hard reset the device by pressing the reset button at the back along with the action button and the down on the volume button, at the same time. The problem was not immediately solved then, but I left the device on overnight and to my surprise it was fully functional again.
Oct 04, 2009 | HTC Touch Viva Cell Phone
HTC Touch lost the WiFi ability
I think phone needs software reset. Below is the link about performing soft reset and hard reset on HTC touch. Try soft reset first. if it doesn't work, try hard reset. If after hard reset still no success, try to flash firmware. But I think hard reset can resolve the problem. Note, that hard reset will delete the storage entirely, so backup any data befor performing those manipulations.
http://www.hard-reset.com/htc-touch-hd-hard-reset.html
Mar 18, 2017 | HTC Touch P3450 Smartphone
Program page not working in Windows Mobile on HTC Diamond
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Jan 27, 2009 | HTC Touch Diamond Smartphone
HTC P3400 Memory Card data corrupted!
micro sd memory card isnot fromating my pc
Nov 10, 2008 | HTC Touch P3450 Smartphone
Blank screen
Try soft reseting your phone. If that doesnt work then try hard reseting.  To soft reset take the stylus pen and push in the little hole on the bottom of the phone. You should feel a little click and then your phone will restart. Wait until your phone  starts up again and if it still isnt working then do a hard reset.
 To hard reset, hold down the green send button and the red end call button at the same time and continue to hold them down as you then push your stylus pen into the hole on the bottom of the phone untill you feel the little click. Your phone should start to reset.  Be warned you will loose any information saved to the phones memory ie: phone numbers, pictures, personal settings. Anything saved to your memory card should be ok.
If your screen remains blank after trying both resets I would suggest taking it back to where you got it and and have them fix it or replace it.
Hope this is helpful.
Feb 12, 2008 | HTC Touch P3450 Smartphone
File explorer slow
Try soft resetting your HTC Touch.
Hope this helps!
Nicholas
Jan 26, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
120 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
