Question about Motorola Mobility HS850 Consumer Headset
Trying to pair Motorola HS850 to cell but I hold down button and light comes on but won't stay on
I just bought a Motorola HS850. I am trying to pair it with my cell phone. The instructions tell me to hold the call button down until the light comes on steadily..and when it does, I am to open the boom and release the button. Making sure that the light stays on. But my light does not stay on. It only comes on for about 20 seconds and then goes off. Does anyone know what could be wrong with this product?
  • 3 more comments
  • Rachel Schol Mar 26, 2007
    no that is not what my question is pretaining to. I know how to turn the device on. I am questions the pairing method. The light is supposed to remain STEADILY on...it does not. I am trying to find someone else who had the same problem and how they fixed it. Is my headset junk?
  • Devildog07 Mar 13, 2008
    I'm having almost the same problem. My bluetooth was working just fine when i was at lunch from work but on the drive home it doesn't want to work. I tried everything i can think of so i ended up deleting the device from the phone to try to start all over again with the pairing. Well when i try to pair it again i press and hold the call button while the bom is closed until the light comes on and stays steady. Once the light is on i let go of the button and try opening the bom once i begin to open the bom the light goes out and then once the bom is totally open the bluetooth starts blinkin like it should while in normal use but will not pair. I have tried and tried.
  • jtarheel Jul 01, 2008
    I did have the same problem, then discovered this on: http://www.howardforums.com/archive/topi...
    Pay close attention to how to reset:
    Posted by: JohnnyF
    Well, here's what I got back from MOTO support.. I tried this solution and it worked great for about 2 hours, then it started the 20 second cycle connect/disconnect scenario all over again.. I guess the pros still outweigh the cons for me..
    Thank you for contacting Motorola e-mail support, we appreciate your request.
    Thank you very much for your considerations and interest in our products.
    Regarding your concern, we are sorry to hear about the difficulties you are experiencing. In order to correct this particular issue, we recommend resetting your Motorola HS850, resetting your V710 cellular phone and pairing up the devices one more time.
    To reset the Motorola HS820 Bluetooth headset, please connect the accessory to the charger, leave the item connected for 5 seconds, and then disconnect it. You need to repeat this operation 3 times.
    To reset your Motorola V710, please follow the steps below:
    MAIN MENU < SETTINGS < INITIAL SET UP < MASTER RESET (Security code: 000000)
    After resetting your Motorola Bluetooth headset and your V710 cellular phone, please pair up the devices one more time. To pair up your Motorola HS850 with your Motorola V710, please turn on your Bluetooth headset, open the Boom microphone and finally select the following options on the cellular phone:
    MAIN MENU < SETTINGS < CONNECTION < BLUETOOTH LINK < SET UP < POWER ON < back < HANDSFREE < LOOK FOR DEVICE
    We hope this information has been of your help. We remain at your entire disposal for any further questions you may wish to ask.
    If you need additional assistance, please contact our Cellular Information Center at 1-800-331-6456. Our business hours are Monday through Friday from 7am to 10pm CST and Saturday and Sunday from 9am to 6pm CST.
    For information about Motorola products and services, please locate http://www.hellomoto.com/
    Thank you for allowing us the opportunity to be of service to you.
  • dill5428 Jul 02, 2008
    Trying to reset headset so I can put my head set into pairing
  • rhector59 Sep 26, 2008
    i'm holding call button but not staying lit so i can pair it with my phone how can i fix this?
You hold the button with the boom closed and as soon as the light stops blinking you realease the button and open the boom, the light should remain on and steady. promt your cell phone to find it and the code is 0000
Posted on May 26, 2007
The actual solution is with the boom closed and you pressing the call button, while the light is on, you open the boom...This keeps the light on at a steady rate. Then you can pair the device. Ths default password is 0000
Posted on Mar 15, 2008
  • alizmom1996 Oct 20, 2010
    YEAH!!!! Totally worked!!!! Thanks RodStar!
I got mine 'over the net' as the last person put it and it seems to work fine, It's paired with a Samsung A900, an Audiovox PPC-6700 and now an Apple iPhone with no problems. All work fine when holding the button down until the light comes on, then opening the boom. If you try to detect it from the phone it will find a headset or HS850 for use. If you use the 0000 code it will connect. My only complaint is that it won't pair with more than 1 phone at once. multiple phones can be in the profile of the HS850 but you have to disconnect and connect from each phone
Posted on Jul 02, 2007
    Problem Solver:
Motorola Bluetooth HS820: charged headset will not power on?
Posted on Mar 16, 2010
Hs 850 pairing problems..i have just found the answer to most peoples problem regarding the ear peice light not staying on so that the light stays solid..when reading for pairing...
Well the trick seems to be when you push the button to turn it on..as soon as the light starts ..then open the boom asap...
and it should stay on ready for pairing....i have had a problem get my hs 850 to ready for pairing and then found this answer on the net and it worked straight away for me know problems..so i hope this help you all ..
Posted on Apr 20, 2009
It works. Thanks guys!
Hold on to the call button. When the blue light appears, open the boom and the light will stay there steadily. Pair the device and key in 0000
Posted on Oct 20, 2008
Yey it worked thanks guys!
Posted on Sep 24, 2008
ONE WORD....CHARGE IT BEFORE YOU USE IT...WHILE THE LED IS CLOSED START HOLDING THE MAIN BUTTON TILL A BLUE LIGHT IS ON...AFTER THAT OPEN THE LED AND SEARCH FOR IT ...THE ITS GONNA PROMOTE A CODE ... PRESS 0000 ...EASY
Posted on Mar 12, 2008
Pairing works just fine by pushing the button until the light comes on, THEN opening the mic boom... if you open first or push as you open, the light will come on steady for a few seconds, but this is NOT pairing mode.
Posted on Dec 28, 2007
When i need help to find the way how to make the blue tooth work i didn't understand what you do is hold the blue tooth and press the call but the light should come for about a couple sec when it comes on befor the light gose off opean the boom it should stay on (don't try to opean it when the light is off or it's not going to pair) then when the light is still on and the boom is open opean your phone and press the botton that says look hands free than it should open it to a page that say than press look for devices it should find it and now it works have fun ;-)
Posted on Jul 20, 2007
HS850 did blink when holding the button. When released the light would go out in few seconds. When I open the boom as soon as the light came on it stayed on. Pair with the phone, entered code 0000, works great. The HS850 almost hit the trash can. Thanks very much for the help. Comment..the HS850 is tough unit. Before pairing this last time I had to super glue the pivot point on the boom. So to other owners don't give up.
Posted on Jun 22, 2007
  • 3 Answers
Here's a *hopefully* silly question..... does it pair with the cell phone or not? Nowhere in your original post or your additional comment do you say if your device does or doesn't work... just that it doesn't work the way you want. It seems you are saying that it connects for 20 seconds, then the light goes off, and the connection quits too? that would surely be a different problem than one that doesn't connect at all. The real reason for my concern is, the way you wrote the complaint in the first place, it sounds like it connects just fine but the lights don't work the way you would like. Who cares how the light works..... Please be clearer with the complaint if you want a quick and correct solution. thanks for making me smile none-the-less!
Posted on Jun 08, 2007
Had same problem, got headset over net. It was junk! I bought a new one at Best buy, and you can guess what I did with the old one!!
Posted on Jun 01, 2007
Once you hold the button with the boom closed, and the light is on! Then you open the bloom and it works!
Posted on Mar 26, 2007
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
Can't connect a motorola hs850 with a samsung m520.
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
Jun 23, 2009 | HTC G1 Smartphone
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
I can't sync my LG CE110 with my HS850 bluetooth
Mar 11, 2009 | LG CE110 Cellular Phone
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Trying to pair motorola n136 with my sprint rumors phone
Found this when trying to pair mine:
I had the same problem - what I thought was the unit number was not - it is actually HS850. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/...
Basically, hold down the call button until it lights up (steady -not blinking), open the boom, and search for devices in your phone. When it finds it, the passkey is 0000.
Jun 21, 2008 | Motorola Mobility HS850 Consumer Headset
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Sep 16, 2007 | Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
18,714 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
