Question about Watches
Helbros Invincible c.1970 wristwatch hairspring
Information on supplier of hairspring for Helbros Invincible wristwatch c.1970, 17 jewel movement marked R74 88b.
  • twinlionsm Dec 17, 2008
    Thank you for that. Under the balance is a Swiss style cross in a shield and what appears to be P 756. This still means little to me. Any help as to the manufacturer ?
  • twinlionsm Dec 18, 2008
    Well!!! I am impressed. Many thanks for that
  • 2,338 Answers
Take a closer look at the movement, especially under the balance wheel (use an eyeglass). There should be movement code. By that you can find the real movement manufacturer and the hairspring or balance complete will be easier to trace.
Posted on Dec 17, 2008
  • 1 more comment
  • Arturs Kalnins
    Arturs Kalnins Dec 18, 2008
    So, here we are! You are looking for PESEUX 756 balance complete.
    Put on ebay request for that- it might turn up.
  • Arturs Kalnins
    Peseux movements are not produced anymore and you have to wait til so called New Old Stock turns up.
  • Arturs Kalnins
    Arturs Kalnins Dec 19, 2008
    I forgot to tell you one very important thing- go and shop around for watchmakers. Ask them if they can get (or even have) that particular balance.
    And one more: if you have that old, damaged hairsprig left- take it with you and ask if they can recoil and fix it.
    I'd do that, but unfortunately I'm too far (England).
    Best of luck.
I need to take the movement out of my ladies rotary lb77835 has to come out of the front but not sure how thats done
Don't know why this is posted under a Rolex issue or why you would be taking the movement out of this watch. I would suggest taking the back off if you haven't already.
The movement is connected to the crown, so basically if you're going to take out the movement, you're going to end up breaking the watch.
If you're trying to replace the battery, this can be done without removing the movement. I would suggest bringing it to a jeweler. They can replace the battery for ~$10.
Oct 29, 2013 | Rolex Submariner 16618 Wristwatch
How to take oft the back of a helbros watch
dont know much about helbros but if the back doesnt have a slot to use a small flathead screwdriver to remove the back, take it to a jeweler. if you try it yourself you may scratch the back really bad.
May 31, 2012 | Helbros Watches
Im in need of two links for the slimline watch braclet
Thank you for contacting FixYa.
You can usually get extra links from JJ/Helbros but for some reason I can not get their website. I would look for a phone # in the manual and call them. They will want the #'s on back of watch.
Best regards. Jewel
Sep 21, 2010 | Jules Jurgensen 5000YG Watch
I have an "Orient Fineness Ultramatic" men's automatic wristwatch, 35 jewels, approximately 1967 vintage, one-piece case. It runs, but needs cleaning and lubrication. Is there a reliable watchmaker who...
mcdevito75 here, Hello John, Orient Ultramatic, 67" beautifull watch and Vintage, Our Repair Service Directory should have a watch repair person who can service your vintage watch. At the bottom of this page Click on Repair Service Directory then watches. Please be aware, like any machine John, your vintage watch has wear in it, the gears in the gear train, have the slightest play between the teeth, the main spring and hairspring are not as tight (rigid, springy) as they were when your watch was say, 3-5-10 years old, these factors all contibute to your watches off time as a matter of speaking. You may want to consider a complete over-haul of your Orient Ultramatic watch. I am Mike D of the RITE TIME BASICS, listed in the Repair Service Directory here at fixya. (email mcdevito@netzero.com)Or you can choose any of the other fine watch makers here at fixya"s Repair Service Directory.
Aug 19, 2010 | Orient Watches
I have a Fossil Automatic Watch, model ME1032. The case back is held intact by four small screws. I lost one of the screws after I cleaned the movement. Where may I purchase another screw without going...
mcdevito75 here, Almost any jeweler should have another screw for the case back. You may even save a few bucks going to a small jeweler shop over one of the big concerns.
Jun 15, 2010 | Fossil AU4003 Wristwatch
Hi Sir...Thanks. The Hairspring is pretty clean. Thre regulator is now pushed till the slowest setting (-) . But still the watch run fast. Any guidance? :) Alex
If the hairspring is perfectly clean (pretty clean is not good enough), then you have to observe it by using magnification eyeglass. Check out if the coiled parts are touching each other while the balance wheel is in motion. If that happens you need to recoil/repair hairspring and make coiling perfectly even. Also check out if the hairspring is touching balance wheel or coc;k. It must not touch anythining and must expand and retract freely. Coc;k is the bridge on which the hairspring stud and regulator (index) is fitted. When this is sorted but the problem still persists, get back to me again I'll guide you through the next stage of possible solutions.
Apr 14, 2010 | Timex 27191 Wristwatch
Watch tick much faster
You have to clean hairspring. Unless the hairspring is spotless, there is no way the watch will keep time. Make sure hairspring coils are even and not touching. Rate me, please.
Apr 13, 2010 | Timex 27191 Wristwatch
Antique pocket watch
Case info does not help in dating a watch, A movement serial number helps greatly.
r/
David
Oct 15, 2008 | Colibri Swiss CSQ Pocket Watch
Setting Day/date on Helbros wrist watch
As an extra tip, to advance the date a little faster, you can turn the stem and rotate the hours past midnight and keep going until you pass 2 AM, then you can wind backwards, going past about 8:30 and you will hear a 'click', then you can go past 12 am again and the date will change. This makes it a little quicker to advance the date several days.
May 13, 2008 | Watches
Runs Fast
Usually when a watch with a mechanical movement is running fast its is because the adjustment on the hairspring is advanced to far. Since it wasn't running fast to begin with I can assume its because something was knocked loose. It is possible that a tiny drop of oil was on the hairspring and by knocking the watch two coils are stuck together by the oil. (this usually only happens if it has been over oiled by an amature watch repairer) Magnitization is possible but pretty unlikely, unless you play with Big coils of wire that are carrying a LOT of current. Either way, unless you know what you're doing and have the right tools, you are looking at taking it to a Tag repair center. Since a simple tune up can cost about $250, I'd expect to pay $400 to $500 for that one. Welcome to the wonderful world of high end watches.
Oct 29, 2007 | Tag Heuer Aquagraph CN211A wristwatch
Watches Logo
583 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
