Question about ASUS A7V8X Motherboard
Reading error I got the ASUS A7V8X-X mobo and try to change to a new HD. The disk is about three years old and worked fine in other machines as primary master and primary slave. When starting up I get an error message "disk reading error press CTRL-Alt-Del to restart". Is the mobo damaged in some way or are there any jumpers/switches I forgot to change?
    President:
  • 1,179 Answers
What type of HDD is this? IDE; SATA; or SATA II? The problem probably is that you are trying to use a SATA drive with a SATA II board. They are not backwards compatible. Hope this helps.
Posted on Dec 21, 2008
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Did I fry my ASUS A7V8X-MX motherboard? I bought an old computer(with this moboard) that was working. I opened it and put in my old HD to slave it. Rebooted to get into the BIOS (just to check things...
I do not think that this problem is to do with your Motherboard. If you had fried your Motherboard, you would not see anything when you started the computer, you especially wouldn't be able to get in to the BIOS if your Motherboard was damaged because the BIOS is accessed straight off the Motherboard itself. You will notice that if you take out all the Hard Disks in your computer, you will still be able to access the BIOS.
This problem is probably due to a corrupt Hard Disk. Maybe you set the old Hard Disk to the Master or whilst moving your computer you damaged the other Hard Disk. This problem is known as the Windows Reset Loop, your computer will not get past a certain point in the start-up process and will then restart itself and do the same thing over and over again.
This could also be caused by a problem in your BIOS, when you did the CMOS reset, it would have probably knocked out all of the stored data. When your computer is starting up, you must go in to the BIOS and check which drive the bios is set to boot off. Even though your Slave Hard Disk is set as a Slave, you can still set the computer to boot off this drive, and if this drive is corrupted it will not boot, it will go in to the Windows Reset Loop.
If the problem still persists, i recommend that you remove the old Hard Disk which you have put in and try and boot off the Master as a single drive. If this still doesn't work, set your other Hard Disk as the Master and remove the other drive and try boot off that one.
If you would like further assistance with this problem, pleas do not hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 01, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
BIOS issue or ? Rebooting PC into BIOS on ASUS A7V8X-X ACPI BIOS Revision 1003, 13.2.2003
If you lose time and day, means the little battery on your motherboard is done. Get a new one, replace it, should be fine then. As far as booting into BIOS, there should be a boot option, and you can boot into a hard disk, a usb or a cd rom drive. Of course in this case, choose the hard disk that has your operation system on it.
May 30, 2009 | ASUS Computers & Internet
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Sata unable to recognize my book 500gb
The A7V8X-LA motherboard only supports SATA1. Your new hard drive is likely SATA2 (SATA-II). You'll likely need to change jumpers on the drive to make it compatible with SATA1.
It's a tiny bit slower than SATA2 (okay, twice as slow). But, it's still faster than PATA (IDE).
David L. Burkhart
Burkhart Technology Services
http://www.BurkhartTech.com
Jun 22, 2008 | ASUS A7V8X Motherboard
ASUS A7V8X hangs @ splash screen
Just because an installation may hang does not mean the board is dead. If possible I would connect the hard drive into another PC and check for a virus. While in another pc you can remove important data from the drive & copy to a CD/DVD. Than download the drives Mfg's drive software setup program that will run in Dos mode from a diskett. Reformat the drive and install a fresh copy of windows. You might find that is the only problem. Xp does not always install correctly. There may be a software or hard ware making windows hang.
Jan 12, 2008 | ASUS A7V8X Motherboard
ASUS A7V8X Motherboard Logo
185 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
