Question about Logitech FreePulse Wireless Consumer Headphones
Logitech freepulse headphones not charging?
I charged the wireless reciever and the headphones. The reciever light comes on, but the headphones don't light up at all. They just suddenly stopped working.
Any ideas on how they could be fixed, or should I just have them replaced under warranty?
  • 3 more comments
  • edrama Jan 13, 2009
    i have this problem. i emailed logitech about the problem, but have not received a response yet. it's driving mw crazy.
  • Anonymous Jan 31, 2009
    same problem
    when you plug the headphones in to charge does the orange light flash then go off instead of staying on and charging?
  • sgotama09 Jan 31, 2009
    So it cant be fixed????
  • four5three Feb 19, 2009
    I have the exact same problem, just started happening out of nowhere! One day they worked fine and then didn't work at all.
  • Anonymous Mar 18, 2014
    AR headphones suddenly quit working. The red light on the charging station is blinking, but the batteries seem to be weak? Is it time to replace the batteries or is something else wrong?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Posted on Feb 28, 2009
  • Hadi Apr 09, 2013
    Thanks for the guidance Ryan. But, for someone who hasn't got any knowledge about soldering the process makes only a little sense. Please is there any way you can put a video on about this as I don't want to ruin what is left of my headphones (and of my hands with the use of razor blades).
  • Hadi Apr 09, 2013
    Thanks for the guidance Ryan. But, for someone who has no knowledge about soldering at all, can you please post pictures or a video about this as I don't want to ruin what's left of my headphones (or my hands with the use of razor blades).
I had the same problem, the headphone is faulty and will be replaced under warranty.
Posted on Jan 07, 2009
Suddenly no sound.
yes they do, if its connect via usb cord to pc or wall wort
does no sound cause from no power light (blue light on right side) if so you might have bad batteries this has happened to me before , there not user replaceable either bummer
May 07, 2015 | Sennheiser HDR 180 Wireless Headphones
The green charging light is not coming on when the headset is placed on the charging station
Wait to see if it gets a charge on the port. If the headphones don't work, call customer service for troubleshooting relief.
Apr 06, 2015 | Thomson WHP3001BK WIRELESS HEADPHONES
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
My sms audio by 50 cent wireless dongle stopped working after putting it for charging
When I plug in my dongle to charge the blue led light comes on but when I want to use it, it won't turn on??
Mar 08, 2013 | SMS Audio SYNC by 50 Wireless Headphones...
I need a replacement earloop for my freepulse wireless head set.Who do I talk to about that?
You can buy here: http://buy.logitech.com/store/logib2c/en_US/DisplayCategoryProductListPage/categoryid.13978300?resid=UOVD9woHAtcAAAw@Ex0AAAAP&rests=1357202423124
Tim
Oct 31, 2010 | Logitech FreePulse Wireless Consumer...
My Freepulse headphone won't pair anymore. Both components charge, both both of them display the red LED light. I've tried the override button on the transmitter, and I've tried holding the power button...
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Jun 29, 2010 | Logitech FreePulse Wireless Consumer...
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
FM wireless headphone batteries not charging . Green light does not come on at all. Red light comes on sometimes.
you need to replcae the charging pin of your head phone, it is having loose connection............
Jun 20, 2009 | Philips (33-01-031) Headphones
Logitech FreePulse Wireless  Consumer Headphones Logo
1,076 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
