Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sudden picture problems - color distortion and "negative" picture appearance
I've owned my Sony KF-42WE610 for about 3 years now and all of a sudden when I came home and turned on the TV something was wrong with the picture. Certain colors do not appear to be showing up and the picture generally has a pink tone to it. Overall the picture is very snowy and the best way I can descibe the picture is that it has some sort of a "negative" effect. I'm wondering if this is a bulb problem given that I've had the TV for 3 years now, but I want to be sure before going out and buying a new bulb. Thanks, Chad I had a problem with my Sony LCD projection KF50WE610 screen developing blue spotched. I replaced the buld and it did not fix the problem. How do remove the blue spots that appear?
  • 10,594 Answers
Symptom shows problem with Light Engine circuit and most probably 3 LCD drive section in light engine.
Does TV give any error blinks on standby light?
Posted on Dec 17, 2008
  • Sony Master
  • 19,396 Answers
This looks more like a convergence problem, if you have light the lamp is ok.
Try first unplugging the TV set power cord (and all other cables) for ten or twnty minutes, to reset the unit.
  • Ginko
    Ginko Dec 17, 2008
    Hi Chad, I was answering to the first problem on my first comment, in your case:
    "Chad
    problem. How do remove the blue spots that appear?"
    As I already stated, if you have raster the lamp is ok, as you can see it is generating light.
    If the blue spots are static, like ink stains that is definitively a faulty LCD.
    If the blue spots are on only when you have sygnal, and moving, it can be a faulty LCD, or a problem with several video ICs on the motherboard, this job requires thorought testing the unit, and some test (the ones on D board ICs) must be done with live power and require an adequate knowledge.
    This job must eb done by a technician or by an experienced electronic repairer.
All of a sudden, my pictures have a pink splotch running vertically across the center of the picture. This is happening more often than not, and I can also see the splotch on the image display when I am...
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A problem has been discovered in some of the CCDs used in Panasonic, Fuji, Sony and Canon digital camera and digital video camera products that causes images to appear distorted or not to appear at all. And the says apologize for the considerable inconvenience this represents for your customers. Along with our respectful apology, we would like to advise our customers of the details of this issue and our policy for handling it, which are as follows.
The Malfunction:
Among the CCDs used in the affected products listed above, it has been confirmed that, especially under high-temperature/high-humidity environments, the internal wiring may come undone in some places.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images. These symptoms can be confirmed on the LCD monitor. The same symptoms may also occur in recorded images:
* images do not appear
* images appear distorted
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; this, isn't a good new, but hope helps to solve it.
Jun 14, 2011 | Panasonic Cameras
Dim and reddish picture SONY lcd kf-50we610
Light Engine/optical block
Encompass Parts Distrubtion 1-800-638-3328
Apr 14, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
KF42WE620 Red picture
I have the same problem that started tonight! It has a red hue that I can't get rid of,I tried all settings etc. Now what.....Any ideas?Thanks
Jun 10, 2008 | Sony XL-2100U Projector Lamp for...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
I'm having a problem with the picture tube on my 51 inch sony rear projection TV, 3 years old. All of a sudden the display that reads "Video 1" or "Video 2" is slanted and so is the...
It is very common to have the convergance circuit on these sets go out and cause display distortions. Are the colors separated or is just the picture slanted?
Dec 31, 2007 | Televison & Video
60 " SONY KF60WE610 screen went greenish
Depending on when you bought this TV, this could be the lamp. Does the red light below the green light come on? (That's the lamp light). This light typically comes on around the 3rd year of use for an average individual. I've recently enountered the same problem and will try to replace the lamp myself. Apparently its very simple.
Dec 01, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Distorted picture
dont touch those lenses that is not your problem the problem is your convergance ic are bad replace them and the fuses and this will fix your problem
Sep 15, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
123 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
