I was watching TV and then the picture went black. I tried turning it on off, the only thing that happened is the the on-off button flashed a few times. I unplugged it, disconnected cable line, hooked back up. None of the buttons work. Can't get the VHS tape out. I love this TV - its white and in my kitchen. Any ideas? Thanks you.
i do know that this unit which i have also if you plug the tv up and turn it on several times it will reset the tape drive and take out all slack on the tape and it will then eject the tape then clean the tape path after you get tape out tv should return to normal but tape unit must be cleaned are the sensor mabe going bad like the end sensor and so forth etc..
I have an Admiral GOJ 12347 tv and the picture is almost completely black. I can see a faint outline...
(More)
I have an Admiral GOJ 12347 tv and the picture is almost completely black. I can see a faint outline of the picture in "green" and I cannot adjust the picture. It looks like it just needs to be adjusted. I do not have the remote and using the "menu" controls doesn't work.
For some reason, I cannot get channels 2-6 on my 13" GE television. I've tried to use the...
(More)
For some reason, I cannot get channels 2-6 on my 13" GE television. I've tried to use the 'channel and scan' features to establish the channels, but to no avail. All other channels seem to be okay. This problem has been prevalent for quite a while, but I'm now just getting after it.
We have lost our remote for our Admiral TV Model GOJ12395 and need to switch from Aux 2 to Aux to...
(More)
We have lost our remote for our Admiral TV Model GOJ12395 and need to switch from Aux 2 to Aux to watch TV!
Thanks
