Question about LG DRD-8160BB (GDR8161BBGDR8162BB) Burner
LG DVD-ROM 8160B
I ERASE EVERY THING NOT KNOWING WHAT IT WAS
SO NOW MY COMPUTER DOESN T RECOGNIZE A CD
    Sergeant:
  • 236 Answers
If I understand this correctly, you erased a cd of data and want it restored?
If this is true, then I am sorry to tell you that you will not be able to get that cd data back.
Posted on Dec 17, 2008
Hi! I have a webcam easyCam Pro HO98669 Ver.1 and my computer doesn't recognise the cd with the driver. What can I do?
Ok it isn't unusual for a CD ROM or DVD ROM to not recognize a CD or DVD insert to it..Ok try this clean the lenses of your ROM using a CD or DVD cleaner disc if you have also try to wept your cd software with a clean dry soft cloth or cotton..If this will not work perhaps you need a new installation cd for your webcam.
Jul 10, 2011 | GE EasyCam Pro Webcam
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Will not recognize cd's but plays and records dvd fine
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device also scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
I have a problem about my LG dvd rom drd 8160b I want to update my driver because other tape cant read
For less than $50, you can get a brand-new CD/DVD reader/writer. So, rather than spending $50 to try to "fix" your DVD-reader, just replace it.
Jun 15, 2010 | Computers & Internet
Computer will not recognize external cd rom drive
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Mar 11, 2010 | Toshiba (PA3438U-1CD2) CD-RW/DVD-ROM...
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
GDR-8160B 16X 48X dvd-rom I need a dvd/cd-rom
Here's a place to grab a new burner:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4974039&Sku=L12-1336
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Sep 22, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
DVD rom restarts xp home
It is the problem of your motherboard check it out to workshop
May 18, 2009 | Sony (2450455) CD-ROM Drive
Cant instal as have no installaltion cd
for all i know cd/dvd rom are automatically detected by windows, so there's no way it wont be recognize by the windows unless you are using win95.
May 15, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Dell Dimension 2300 does not recognize LG GCE-8160B DVD/CD RW ROM.
If IDE drive, you may have to set disk controller to legacy mode in BIOS.
Apr 24, 2008 | Computers & Internet
LG DRD-8160BB (GDR8161BBGDR8162BB) Burner Logo
89 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
