Question about Rimage Office Equipment & Supplies
Have an Everest III disc printer that is not printing good labels. Seems the blue prints OK but the are streaks on the disc where the red and yellow should be printing. Changing the ribbons didn't
If the disc label should be mostly black, when it prints out there are places on the label that print as blue or yellow instead of black. Same thing for other labels but shows up most on the dark labels.
    New Friend:
  • 36 Answers
First thing is to completely CLEAN the printer. All rollers and any point that contacts the ribbons or transfer material.
John Norman
Max Optical llc.
www.maxoptical.com
Posted on Jun 16, 2014
SOURCE:
SOURCE: Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Posted on Jan 21, 2008
  • 40 Answers
SOURCE: Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Posted on Jan 24, 2008
jigeo
  • 57 Answers
SOURCE: Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Posted on Apr 19, 2008
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
How to clean the print head
No easy way to clean the print head. You will need to remove it from the printer to gain access to the area to clean. What does the label look like on the disc? Streaks is probably a dirty print head. If sections of the label are missing it could be the print head or heat roller. Look at the re-transfer (clear) ribbon. If the missing part of the label is left on the ribbon you have a heat roller issue.
Mar 12, 2013 | Rimage Everest II Printer
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
My rimage is printing but there is an 1in mark that appears on all my disk what can it be.....it's almost like its on a roll or something every 5in roll u get the markl..i install new ribbon and...
Is there anyway you can send a picture of the disc with the bad print? It may be a worn our roller which is an easy fix.
My email is - info at techwaredist dot com
We to repair work on Rimage Everest II and Everest III printers regularly.
Mar 24, 2011 | Rimage Everest II Printer
I installed the Lexmark z715 printer driver on my Mac and it is connected fine, but when you attempt to print documents, it prints blank pages instead. The ink cartridges are brand new. Please help me...
Ok, you need to clean the print heads they are probally clogged, what operating system are you using on your computer? I can walk you thru on what to do, very simple, if you have windows xp, do this: Go to start then all programs then go to your printer, there should be an option to align paper, clean print heads, print test page, you need to pick clean print heads, then after that print a test page, then if you see something printed but not good qaulity, clean print heads again....if this doesn't work you can take a damp cloth and wet and wipe under the ink cartilige where the ink comes out but is dried and clogged up until you see a rainbow streak of red, blue and yellow, be carefully not to wet any other part of cartirige, you can use a moist q tip if you want.
Jun 28, 2010 | Lexmark Z715 InkJet Printer
Good morning, having problems with zebra printer 110xilll Plus. white streak down middle label. V
You can try cleaning the print head with Isopropyl Alcohol, if this doesn't fix it - you printer will require a new Print head
Jan 20, 2010 | Zebra 110Xi III Plus Thermal Printer
Having problems with the rimage everest printing vertical streaks a lighter shade of the color that should be printing
The rollers under the Transfer ribbon is dirty, I am sure if you look at the streaking it will line up with these rollers. Clean them with alcohol.
John Norman Max Optical LLC. john@maxoptical.com 610-269-7033
Nov 03, 2009 | Rimage Everest II Printer
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Rimage Everest III printing quality issues
Hi Jay, do you have any idea how many discs have been printed with this Everest Printer?
Your issue sounds like a hardware error, not an issue with the software you are printing from. Most likely the printhead needs to be replaced, or the control board. Printhead replacement costs approx $1200.
- techware dist
Apr 14, 2008 | Rimage Everest Autoprinter Thermal
63 people viewed this question
Top Rimage Office Equipment & Supplies Experts
kevin gabrik
kevin gabrik
Level 1 Expert
John Norman
John Norman
Level 1 Expert
Wbix
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
