Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Unable to turn on the CPU
Whenever I turn on the CPU, there's a long beeping sound that repeats and the numbers 3 & 4 are lit. What am I supposed to do to solve it?
  • Laurent55 Jan 22, 2009
    exactly same pb.. no idea on how to solve it !
  • Laurent55 May 11, 2010
    how to change the bad memory module?
Read in another site that the pb may be linked to a compatibility issue between the pc and a logitech webcam driver.. if you have then try to remove it..
Posted on Jan 22, 2009
  • 115 Answers
This is an indication of bad memory module. Change it/them.
Posted on Dec 17, 2008
How to turn off child lock of LG refrigerator vth model number GL- 528?we already tried by holding it for 3 sec....it doesn't works at all....nd have a beep sound too
Pressing this button stops operation of other buttons.
"Locking" or "Un-Locking" is repeated whenever pressing the CHILD LOCK button. (For "Locking" or "Un-.Locking" press the "CHILD LOCK" button for 3 secs.)
When 'CHILD LOCK' is activated, pressing the other buttons would not work.
Aug 22, 2016 | LG Washing Machines
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
I am slowly rebuilding my computer. When I nearly got it finished, and turned it on, it came up with "Windows Was Not Found". Knowing what to do, I turned everything off, unplugged it properly, and...
Check for motherboard. use only 3 parts:
motherboard
PSU
CPU + COOLER
Connect your motherboard to PSU and see, if any LED light comes from motherboard. If LED is on, then try to turn motherboard on and see if cooler works.
Are case wires (power +, power -, hdd +, hdd -, reset+, reset -, power led+, power led - and speaker wire ) connected correctly?
Those wires look like this:
front-panel-headers-nsatmeh50lx5u1woeaeqllmn-4-0.jpgThis image is just reference.
If the power wire (sometimes called POWER SW) is not connected correctly, when you press the power button of case, PC just won't turn on.
If PC turns on and CPU fan spins, then try to add RAM, Graphics card and try again.
Next step is to hear BEEP sound. One short beep sound is normal, anything else is not normal and indicates the problem of the specific hardware according to the sound code. Sound code is BIOS dependent. In case ASUS A8V-E Deluxe, it is Award BIOS. Check below for Award BIOS beep codes
1 long, 2 shortIndicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
1 long, 3 shortVideo card not detected __ (reseat video card) or bad video card
Beeps repeating endlessly __ RAM problem.
Repeated high frequency beeps while PC is running __Overheating processor (CPU)
Repeated beeps alternating high & low frequency ___Issue with the processor (CPU), possibly damaged
Mar 17, 2017 | ASUS A8V-E Deluxe Motherboard
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Unable to register, not asking for password
See below for complete instructions but think you have missed out part 2......
Reregister the handset or add additional handsets.
1. Remove all handsets form charging or Main base unit.
2. On on Main base unit, press and hold Page button for 10 seconds until beep. ( Not paging beep )
3. On 'unregistered' handset press and hold Redial & Calls buttons ( Top left and top right ) until 'bs-' appears.
4. Enter handset number ( eg: bs-1 ) then the pin number( could be 0000 but check your manual ).
Cheers
Monty
Feb 16, 2008 | British Telecom Freestyle 2200 Trio...
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
105 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
