(1) Apply a light coat of engine oil to the threads and under the heads of the cylinder head set bolts.
(2) Using several steps, uniformly install and tighten the 10 cylinder head set bolts and plate washers with a 10 mm bi-hexagon wrench in the order shown in the illustration. Torque:
70 N·m {714 kgf·cm, 52ft·lbf} (c) Mark the front of the cylinder head bolts with paint.
(d) Further tighten the cylinder head bolts 90° as shown in the illustration.
(e) Check that the paint mark is now at a 90° angle to the front.
cam bearing caps; Using several steps, uniformly tighten the 10 bearing cap bolts in the sequence shown in the illustration.
Torque:
No. 2 Bearing cap -
30 N·m {301 kgf·cm, 22ft·lbf}
No. 3 Bearing cap -
9.0 N·m {92 kgf·cm, 80in·lbf}
need the torgue settings,head, main bearings etc.
