Question about Braun Syncro 7526 Electric Shaver
Razor won't shut off
Razor won't turn off
  • tnyffeler Jan 02, 2009
    i was using the razor like normal and suddenly it wont shut off. The switch wont go all the way down to the off position
  • Anonymous Jan 05, 2009
    Probably a build up of hair dust in the crevices around the switch. Try wiggling the head cleaning brush in & around the grooves that the switch slides in.
What happens if you blow a fuse on a razor mx500 dirt rocket, would it explain the bike shutting down and not turning back on
This site has everything to check if scooter is not running regarding fuse problems.
Mar 13, 2016 | Razor Cycling
Why does my shaver turn off automatically when I turrn it on?
Replace the razor head making sure it sits secure so it won't block the cover and let it spin freely.
Oct 21, 2013 | Braun Series 7 9585 Hair Trimmer
My ground force razor drifter drive slow with a full charge it won't go fast
Well most likely, your batteries are weak. When the charger shuts off, the batteries have stopped taking charge, but they're not necessarily at full strength, especially if they've been sitting for a while without being charged. Connect the wires from the power switch together and try again. If it works replace the switch. If not, turn the motor shaft both ways. If it makes clunking noises, it's cooked. Otherwise you probably need batteries. Ive never seen a throttle or controller cause slow operation. And also always keep your tires pumped up.
Sep 29, 2013 | Toys
Changed battery but won't turn on
It could be the starter motor it self. Also check the ignition switch just to be safe.
ITP tires
Nov 10, 2012 | Razor USA Razor Dirt Quad Electric ATV
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
Razor dirt rocket won't start
Could be in gear if red light is on
Feb 28, 2012 | Razor MX500 Dirt Rocket
I have a 42cc homelite chainsaw that I put on my razor mini chopper when there is weight on back tire the bike won't go but as soon as I pick up back tire it will spin how do I solve this problem
If you replaced the motor on the original razor with the chainsaw motor, you may have a gearing issue as the load on the chainsaw is much less than the load on the razor.
Aug 31, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My unit won't turn off.
I have a Remington electric razor fully charged and it won;t shut off unless I plug it iin. When I remove the plug in cord it runs all the time?
Dec 14, 2009 | Remington MS5500 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
267 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
