Question about Intel D845PESV/ D845PESVL MB, Retail Box (GXMBD845PESV) Motherboard
MB Intel D845PESV n?£o carrega
MB Intel D845PESV de repente parou de funcionar. Ao ligar fica apenas o LOGO da Intel e não sai mais desse estágio. Será o BIOS?
Outra questão: Como faço para eliminar o password (do BIOS) de um DELL GX 110 e ter acesso ao SETUP?
map9966
  • 2351 Answers
SOURCE: Probblen in Additinol RAM
Hi Raj_jp, the Intel D845GLLY board must have SPD memory to function correctly in the system. The memory you added (512MB) must not support SPD. To help you understand what SPD is, you can click on this link which explains what SPD is.
http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci533524,00.html#
The memory sold in this next link will function in you're Intel motherboard. http://www.memory-up.com/Memory/IntelD12696.html
So will the memory in this next link.
http://www.memorystock.com/memory/IntelD845GLLY.html
If you bought the 256MB memory recently, you should be able to return it & have it exchanged. The link above also lists the part number for the memory.
Good Luck!
Remember you're Intel motherboard uses you're system memory to run the onboard video card. The total amount of memory the video card uses can be adjusted higher or lower. You can adjust this in the bios. Go to Advanced Menu. Page 40 in the Intel user manual. You can download you're manual at this link.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
Mike
Posted on Jun 02, 2008
SOURCE: urgente¡¡¡¡¡¡¡¡¡¡bios de mother m748lmrt
QUE NUMERO DE BIOS TIENES EN ESTE MOMENTO
ESA INFO ES LA MAS IMPORTANTE PARA PODER AYUDARTE
DEBES FIJARTE EN EL NUMERO DE PC BOARD
(ES UNA ETIQUTE QUE DICE : VER:XX)
Y AL INICIAR, TE METES EN LA BIOS Y TE FIJAS QUE VERSION ES LA QUE TU TARJETA LLEVA.
Posted on Jul 29, 2008
SOURCE: porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
ai tienes alguna forma de ayudarme via on line te le indico mi email: cyberchica_otra_vez arroba otmail punto com soy de Venezuela muchas gracias por su ayuda.
Posted on Oct 02, 2008
sodeep
  • 3267 Answers
SOURCE: mouse not working
Try a USB mouse......sodeep
Posted on Mar 27, 2009
  • 19 Answers
SOURCE: I updated my intel D845PESV bios now my ps2 mouse not working
update u r bios from intel site www.intel.com
Posted on Aug 24, 2009
Nao consigo retirar o erro 5b00 da minha mp490, oque fazer?
https://translate.google.com
O erro 5B00 est? se referindo ao contador de tinta. Voc? deve poder redefinir o contador de tinta e continuar usando a impressora como antes, seguindo estas instru??es:
1. Desligue a sua impressora Canon MP490
2. Pressione e segure o bot?o parar / reinicializar
3. Enquanto segura a parada / reinicializa??o, pressione o bot?o liga / desliga na impressora. Isso ligar? e desligar? a impressora novamente
4. Solte o bot?o de parada / reinicializa??o e pressione-o novamente duas (2) vezes seguidas, com movimentos leves, tocando. Por favor, lembre-se de manter o bot?o on / off pressionado enquanto
5. Solte todas as teclas que estava pressionando e espere at? que apare?a o descanso na sua tela
6. Pressione o bot?o de parada / reset novamente por mais cinco (5) vezes consecutivas e, finalmente, pressione o bot?o liga / desliga duas (2) vezes rapidamente
7. Desligue a impressora e ligue-a novamente, e ela dever? funcionar corretamente
Oct 09, 2018 | Computers & Internet
Algu?m possa responder erro c?digo 9 krups xp7220
O sensor de temperatura na parte frontal da carca?a da caldeira (atr?s do painel frontal) n?o est? detectando nenhum calor na caldeira. Freq?entemente ? o borne de terminal desconectado do sensor ou o sensor inteiro n?o est? mais preso na caldeira. A solu??o da Krups ? para substituir a caldeira completa, mas no passado, eu revendi o terminal de volta ou colei (com cola resistente ao calor) o sensor de volta para a caldeira.
May 26, 2018 | Krups Coffee Makers & Espresso Machines
Tenho uma kawasaki zr-7 tou a ter uns problemas nuns tubos que suponho serem respiradores em cima do carburador e a mota parece trabalhar a dois cilindros sabem dizer o que e?luis_simoes1987@hotmail.c
Oi, Luis voc? precisa de "CINCO" coisas para que um cilindro funcione corretamente:
1. COMBUST?VEL: a fim de validar o seu combust?vel n?o come?ar algum fluido de partida para o filtro de ar e apertar o bot?o de arranque, se ele acionar e funcionar por alguns segundos, ent?o voc? sabe que voc? tem um problema de entrega de combust?vel. Bancos multi-carb deve ser bancada "SYNC"
2. SPARK: remova a vela de igni??o e com ela conectada ao cabo da vela ligue os fios a algo de metal, voc? deve ver uma fa?sca branca azulada se n?o tiver uma vela de igni??o defeituosa, cabo da vela de igni??o, bobina de igni??o, condensador, CKP, ECM, sensor ou a fia??o intermedi?ria.
3. COMPRESS?O: voc? deve ter pelo menos 80-100 PSI para a maioria das bicicletas, os motores multicil?ndricos devem estar entre 10-15% um do outro, se n?o realizar um test de vazamento, voc? pode ter uma v?lvula ou furo queimado ou dobrado pist?o ou an?is quebrados.
4. TEMPORIZA??O DA CAM: confirme se as marca??es de tempo est?o alinhadas para ver se a corrente ou o regulador est?o desgastados e a corrente pulou alguns dentes.
5. TEMPO DE IGNI??O: em bicicletas mais antigas, verifique se seus pontos n?o est?o fechados, a placa de cronometragem n?o se soltou e confirme com uma luz de sincronismo para fun??es adequadas de retardo e avan?o, em bicicletas mais novas, onde a temporiza??o ? controlada por um ECM. n?o-ajust?vel verificar voc? CKP, TPS, MAP, O2, sensor ou sua contraparte para a integridade.
Para obter mais informa??es sobre o seu problema e downloads "GRATUOS" valiosos que voc? precisar? para visualizar ou imprimir, clique nos links azuis abaixo. Boa sorte e tenha um dia maravilhoso. Zr 7 Missing Running on 2 cylinders
http://kawasakiworld.com/zx-12r/43722-sounds-like-running-3-cylinders.html
Kawasaki ZR 7S Service Manual
OEM Parts for Kawasaki
KAWASAKI ZR 7S Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 24, 2013 | 2003 kawasaki ZR-7
Meu telefone perdeu todas as funções gostaria de rest, ou não sei se da pra formatar ou fazer o bot que nem o pc. Não sei mais que faço.
Alo grande.
Em primeiro lugar, eu so formatei ate agora Nokia 6600 e nokia N73 com os mesmos codigos.
Mas tu podes usar o mesmo codigo para alguns outros telemoveis.
Faca o seguinte Apos carregar bem o cellurar.
1 _ desliga o celular
2 _ volta a ligar o celular.( em seguida pressione logo nas seguintes teclas: Verde de atender, tecla 3, e tecla ASTERIX *. tudo ao mesmo tempo...) ate sair um sinal k seu celular esta ser formatado.
Se nao der, digite os seguintes codigos.. *#7780# ou *#7370#
Boa sorte
Nov 25, 2010 | Computers & Internet
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Eu praciso do driver do celular k620
Aparentemente não é preciso driver, deligue seu aparelho e conecte ao PC, ele funcionará com pendriver, no Meu computador aparecerão dois discos removiveis onde estarão seus arquivos de dedos, audio e video. Se voce conecta-lo ligado, ao PC, não será reconhecido e ocorrerá apenas recarga de bateria.
Dec 16, 2009 | Sony Ericsson K610i Cellular Phone
RICOH AP410 HAS A SC541 FAULT
sc541 is the thermostat, in the fuser section. i would personally change both the thermostat(s) and the thermistor(s).
Jun 20, 2008 | Ricoh Aficio AP410N Laser Printer
HELP
Ya le cambiaste las salidas de audio,si es asi checa el transistor del relay puede que este danado.Buena suerte.
Feb 16, 2008 | Teac AG-V8060 Receiver
Intel D845PESV/ D845PESVL MB, Retail Box (GXMBD845PESV) Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
