Question about Zenith Z46Z83D 46" Rear Projection Television
Zenith 46" with a "hour-glass" picture.
My 46" Zenith rear projection TV now has a permanent "Hour-Glass" shape picture. It started out that it would come and go, but now it just stays. I have pulled the convergence board out, but I do not know where to get it checked or repaired/replaced. Is this the most likely problem? any chance it could be something else? I also cannot adjust the convergence on the TV.
    Problem Solver:
  • 8 Answers
Replace convergence ic's and 1ohm resistors near ic's check all solder connections on convergence board also check 110k ohm resistor in front of H.O.T on main deflection module.
Posted on Sep 02, 2007
    Novelist:
  • 192 Answers
If the hour glass figure is a seperation of colors that appear to be convegence mis aligned, then, the convergence ICs would be the problem. If the picture is clear and you have a bending on the sides then the pincusion circuit in the horizontal circuit is where to look. Be careful of this circuit, it does control the high voltage. The only way to have a board checked is to have an Authorized Service Center look at it. It does, however, sound like there is a cold solder joint in the power supply that has gradually opened up and now is permanantly open. Call Zenith (LG) to see who they recommend.
Posted on Mar 25, 2007
Just recently my GE 46GW 948 46 in. Rear Projection Television when turned on goes from a good picture to an hour glass shape and an almost 3d like picture.When I turn it off then on I get a good picture...
Sounds like a loose solder connection on the Convergence board or the convergence power board. If you are savvy and electrically safe, tap on the boards with an insulated screwdriver to see which has the loose connection, and you can resolder to fix. Repair from a service center = $150-300
Jul 26, 2010 | GE 46GW 948 46" Rear Projection Television
Picture goes into an hour glass shape. red/orange color on one edge of the hour glass and green/blue color on the other edge.
You have a bad cap or two in the horizontal deflection [Pincushion problem] and you may have to look for a burned resistor. Use your vision to inspect burned areas on the board, this will most likely tell you where the problem may be. Area should be between the Vertical and Horizontal deflection. Look for the flyback transformer that is the board you are looking for! Hope this will you a good start. Thanks for asking!!
Oct 11, 2009 | Zenith IQB60M92W 60" Rear Projection...
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Zenith 50 In Rear Projection Hour Glass
My picture is a double image and has a sideways hourglass on the screen. Please help me!
Oct 08, 2007 | Zenith IQB50M90W 50" Rear Projection...
Green Solid Hour Glass
possible convergence amp ic's failed should be under $300.
Sep 05, 2007 | Toshiba 46H84 46" Rear Projection...
Picture shaped like hour glass
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Televison & Video Logo
144 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
