Question about Ricoh Aficio 1035 Copier
Hello hi there, my name is nizam from malaysia country..i have some problems here and need an assistant regarding ricoh aficio 1035...can you assist me?
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the problem?
Apa masalah tu?
Posted on Jan 19, 2009
Ricoh aficio 1035 copier, functioal problem SC390
The TD sensor could be bad. But more than likely you need to replace the dev material and the drum and charge roller
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Hi my name is Emily I have a question for office procedures module that I am studying at TAFE. I looked this up on the internet, however the site where I can access this information is being...
Hi Emily,
Click here to download the User Manual General Setting Guide for Ricoh Aficio MP161SPF. Please refer to Fax Section (4) for the required details about setting up fax.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 03, 2011 | Office Equipment & Supplies
I am looking for scanner driver of Ricoh Aficio 1035 3 in 1 printer
hello mate. go to www.ricoh.com.au and under the downloads you will get the scanner driver.
Dec 19, 2010 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok...
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
May 09, 2009 | Ricoh Aficio 1035 Copier
Error code sc690
check the laser cable that is this broken somewhere
Nov 24, 2008 | Ricoh Aficio 1035 Copier
Hello MR dricha
The firmware is only available on Ricoh service website. You have to be an authorized service technician to get in. It also require a special flash memory card that is pcmcia based as well as a $300 software program to put it in for a company in Germany. It's better to find a technician in your area to do it. You may find another solution around by checking out copytechnet.com. It's a free website for copy technicians. There maybe a Ricoh technician who can assist you on there.
Sep 12, 2008 | Ricoh Aficio 1035 Copier
Connecting ricoh 1035 to pc
connect your copier to a switch or router.
Goto user tools/counter. Select interface settings. Enter the IP address of the copier, enter the gateway address to the router. Press file transfer. Turn the deliver server on. It will take a few seconds but it should populate the IP address to the computer that desktop binder is installed to and insert the users assigned to the scanner program.
Sep 02, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
75 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
