Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Thank you for your answer concerning new USB devices
In your answer you said that it's a pity i do not have a registry backup.
I have found that my Registry Healer application did save such complete record, but this is old backup from a few months back.
what happens if i restore this old backup? do i lose important current data? do you recommend it?
thank you again, you have been very kind.
  • 1,879 Answers
You will loose current system information (what program is installed) but not saved data onto the disk.
backup the current registry before applying the old one and reboot the computer after applying the old registry. this is the last resort and it might render your computer unusable (windows will not load). only do this as a step to try before deciding to re-install windows.
the registry is windows itself.
Posted on Dec 17, 2008
HOW TO UNWRITE PROTECT 8GP USB FLSAH DISC
I was lead to this site in search for myself to be able to remove previously downloaded files, in my case, windows media player files. Anyway, I found a way to remove my files from my mp3 player to make room for new files I wish to put on. My computer is XPwindows software. OK, what I did was
1)Start menu--my computer
2)locate device, eg.Rmovable Disk(Fsmile.gif, and right click mouse
3)look for 'Open as Portable media device
4)Double click icon(should be only one)
5)Now proceed to remove old files, this time it will allow after the first time it says are you sure you want to remove file, click yes.
Sep 21, 2011 | Computers & Internet
My 1 tb wd hard drive was working fine for many months then all of a sudden was not picked up by the autoplay feature one day or could not be found on my computer file.the hard drive is found in disk...
Have you tried a different USB port? If you have and it still dose not work then I would do the following.
Select My computer
Select Manage
Select Device manager
Select the Diskdrives
Find your USB HDD esternal
Right click and select uninstall
Then scan for new hardware this will reinstall the drivers for that device.
Often the device driver or registry becomes corrupt this will 9 times out of 10 resolve the problem.
If this still dose not resolve it test your Drive on another PC to make sure its not the External HDD that is having a controller problem.
Jul 30, 2011 | Western Digital My Book Essential 1TB...
I cant delete my files on my flash drive everytime i click it the WRITE PROTECTED always prompt! that i need to unlock it
I found this on another site, I tried it down to finding the usb device, you do the remaining part at your own risk, I'm very cautious about editing my registry.
Gary
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
# # Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protected_error_for_the_flash_drive#ixzz1EnkYwY1p
Feb 23, 2011 | Home
I have an X500 and it contains backups of my main XP desktop machine and a Vista laptop. I have a new laptop running Windows 7. The external drive does not appear when plugged in. Lights are on but no one...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jan 15, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
I have Transcend storejet 500GB external HDD is nor working pls provide me the software for it. Thanks
click here Click on above link select your model and download driver then install. Also follow below. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Oct 18, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
My USB problem
NO, don't go t registry if you don't know what to do.
search the web and download the USB 2.0 driver, and install it.
Dec 16, 2008 | Microsoft Windows XP Professional With...
Problem accessing songs on Philips HDD065/05 Jukebox
What you have to do is this: 1) The HDD Detection tool Connect the device to the PC, load up Musicmatch. On the left click "Portable Device" tab, wait for the PC to show your device. The device should show as "Philips GoGear" if it's showing as "Philips Nike" go to "Tools" on the right, click "Settings" click drop-down menu & choose GoGear. You need to do this everytime you transfer files. If that doesn't work, you need to do this: 2) Manual Re-Install You can re-install the player manually by doing this : - connect the player to your pc by USB cable - uninstall all Installed software for the player - remove device from Windows Device Manager : - Desktop - right click on "My Computer" - select Properties from the menu a new windows appears: System Properties - click on the tab "Hardware" - click on "Device Manager" a new window appears" The Device Manager navigate to the player (should be shown as Philips Nike) at the USB Devices - right click on the player - select "un-install" from the menu - Windows will unsinstall the device - If the player is not listed, the device has been deleted Now to edit the Windows Registry: (Note: Mistakes cannot be un-done so be VERY careful) 1. Disconnect all usb devices. 2. Go to the registry (Start -> Run -> type "regedit") 3. Make a backup of the registry -click "file" -click "export" -Search/Create a logical location ("C:\REGBACKUP" for example) -choose a filename ("registry backup Date.reg" for example) -Please pay attention if Export range is set to "All" -click on save 4. Click on the + infront of HKEY_LOCAL_MACHINE -Click the + of SYSTEM -Click the + of CurrentControlSet -Click the + of Enum -Click the + of USB Here you can remove all VID``s -Before you remove the VID you have to set the right permissions, this can be done as follows: Right click on the folder USB and click on "Permissions", select in the window that pops-up Everyone and and select "Full control" at the permissions. 5. Reboot PC without ANY USB devices connected - install the software and plugins - connect the device to your pc by usb Check if device works and if still showing as "Philips Nike" try the first step again. Hope this helps, Weedy
Dec 20, 2006 | Philips HDD065 MP3 Player
Wont load songs
Sep 30, 2006 | Philips HDD065 MP3 Player
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
