Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
JennAir W30400P Owners manual. I bought a house with this under the counter mount range. It has the usual display modual problem I see here, but I am actually trying to find a manual for it. Since whirpool bought them out they no longer offer pdf downloads. Any advice? Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
I think you can get downloads from maytag.
Posted on Dec 01, 2007
SOURCE:
How do you fix a JennAir wall oven display? The oven heats and the over light works but no display.
u can pull the display board & the c3 capacitor is usually burnt. Pretty common problem with jenn air. You can buy it at radio shack r any electrical supplier for bout $2 r $3 bucks. You will need some soldering skills but its not to hard.
Jan 10, 2015 | Jenn-Air Ovens
Cleaning a self cleaning oven
I couldn't find any information on that specific model number, but here is a link to a generic Jenn-Air Electric Range - Use and Care Guide which seems to be model non-specific. The instructions for performing a self-cleaning (as well as other tasks) might be the same for yours.
http://www.jennair.com/assets/product/8113P619-60.PDF
Jan 05, 2008 | Ovens
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
Dim light on oven display w30400b jennair
The circuit board is for the display/touch panel. It is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.)
BTW, I had exactly the same symptoms (display goes dim, then goes out altogether.)
Jan 16, 2009 | Jenn-Air W30400P Stainless Steel Electric...
Time and Temp. display on my JennAir Expressions is not working.
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Dec 31, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Jennair s136 drop in range
I have a Jenn-Air S136 and need instructions on how to clean the oven.  Can someone point us in the right direction?  Thank you.
Jan 19, 2008 | Ovens
Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Nov 19, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Need help with re-installation
ovens don't usually come with a cord. check handbook for cable size and you should find a connection block behind a plate at back. just connect to outlet making sure you get connections correct - they are usually identified on terminal block
Jun 04, 2007 | Electrolux EOC6630 Pyrolytic Electric...
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
193 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
