Question about GE Profile JSP47 Electric Single Oven
The left front radiant heating unit does not heat. All other are working fine
  • Stanley Mietus Dec 20, 2008
    thank you, still work in progress,makes sense, I'm on it Monday
    Novelist:
  • 161 Answers
Check the heating unit with an OHM meter.
This is not rocket science. An OHM meter will check for continuity (a break inside the heating unit). Any appliance parts place will have a meter, even Wal-Mart. The meter can be set for AC/DC/ OHM's, Volts, etc.
Set the meter on OHM and touch the two leads on the meter together and the meter arm should move. Now, take the heating unit out of the range and touch one lead to one end of the heating unit and the other lead to the other end. If you get a reading then the unit is good and the switch must be replaced.
No reading, replace the heating unit.
Some parts require knowing how many OHM's but in this case any kind of reading will show there is no break inside the unit (continuity).
You can check extensions cords this way or set it on volts and check batteries. Everyone should have one.
Posted on Dec 17, 2008
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Can one half of the radiant heating element on an Electrolux range go bad?
Radiant heating elements are often dual elements and if your range uses these dual elements then yes, this is quite possible. However, other faults could cause a healthy element to not work properly.
  1. Contacts in the control switch could be burned out or seized,
  2. A wiring connector could be loose or oxidised
  3. The internal wiring may have developed a fault.
  4. The thermostat (if thermostatically controlled) may have failed
  5. Multiple, consequential or other fault conditions may exist.
A DIY 'trial and error' fix may work first time, but could end up being more expensive (and risky) than getting a professional in with the knowledge, experience and test gear to diagnose the source and extent of the fault before ordering spare parts.
I hope this helps.
Nov 17, 2014 | Ovens
My fan has stopped working can i still use the oven,grill and stove
your oven will still work, just not on convection. you can still bake/broil with radiant heat from the oven
Aug 12, 2011 | Ovens
Left front plate dead. Cant seem to find the fuses
there are no fuses on the unit it self -- the stove is protected by the circuit breaker at your main fuse box. if your front plate is not heating up I would say that you need a new heating element.
c...
Dec 31, 2010 | Ovens
Not heating up right
Hi,when Element does not heat up correctly
1. Test for power to determine that the unit is receiving the correct voltages.
2. If the power voltages are correct and you have standard surface burner elements:
1. Test Surface Burner.
2. Test the Receptacle.
3. Test the Burner Switch.
3. If the power voltages are correct and you have solid-disc elements:
1. Test the solid-disc element.
2. Test the Burner Switch.
4. If the power voltages are correct and you have radiant heating elements:
1. Test the radiant heating element.
1. Make sure the controls are set properly that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
2. Make sure the oven door is slightly ajar as per your owner's manual.
3. If nothing else on the Range, Oven or Cooktop is working then:
1. Check the circuit breaker or fuse
2. Test for power
4. Test the broiler element.
5. Check the oven thermostat.
6. Check selector switch.
7. Check oven cycling relay.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION .
Please if no experience, please contact a skillful personnel for assistance.
Thanks for using fixya..and please don't forget to rate me 100%.
Thanks.
Oct 28, 2010 | Ovens
Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Mar 31, 2010 | Neff B1421 Electric Single Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
Check the element with an OHM meter.
This is not rocket science and an OHM meter can be used for many things. Any good appliance parts place, even Wal-Mart will have a meter which can be set to test AC/DC, OHM's etc. Set the meter on OHM setting and touch the two leads on the meter together, you will see the meter arm move. This is simply a test for continuity. Now take the element out of the Range, touch one lead to one end of the element and the other lead to the other end. If you do not get any reading then there is a break inside the element and must be replaced. If you get any reading at all then the element is good and the eye switch must be replaced.
There are some parts which require knowing how many OHM's but in this case you just need to check for a break inside the element (continuity).
You can check an extension cord this way or set it on the volts setting and check batteries. all kinds of fun.
Dec 17, 2008 | GE Profile JSP47 Electric Single Oven
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
GE Profile JSP47 Electric Single Oven Logo
297 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
