Question about RCA DRC313N DVD Player
Power light was flashing,now dead with shorted r319,r320 resistor
Hi! when i received this player the power/standby light was on and nothing else worked.replaced a bad electrolytic cap c321 and fixed bad connections,now the power/standby light flashes.was testing components when probe slipped and there was a fireworks display that would rival the best at new years.when the smoke cleared resistor r319 and r320 were burnt out.now i know that wasn't the problem to begin with,but i would like to know the values of the resistors and the initial problem why it would not work.Thanks in advance.
3 Suggested Answers
SOURCE: VCR portion not working found Damaged Components
Ya rca needs to recall all rca drc8335[tape decks]
I unpluged power to deck [jumper p/s to deck]
use a other vhs deck pluged in avi port
Posted on Aug 17, 2008
SOURCE: no power
standby lite is on the player but the player will not go on there is power going to the dvd thank you
Posted on Apr 08, 2011
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
I have a Denon AVR1603, recently I plugged computer in AUX connections at rear (not loud) and it kept tripping out. Eventually it tripped and now the the on/standby light fashes but nothing else happens....
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Sep 29, 2008 | Denon Audio Players & Recorders
Philips 42pf7621d/10 dead
One of the circuit boards should be replaced inside, probably the power supply, the good thing is that screen is ok and it's a most expansive part, you can take it to the local repair shop for diagnostic and repair.
Oct 10, 2009 | Philips Televison & Video
Kenwood VR-509 Receiver won't power up...
Check all your speaker wires for shorts, especially behind the amp, doesn't take much for something to throw a spanner in the works, like when cleaning house and moving stuff around.
Oct 03, 2009 | Kenwood VR-509 Receiver
Marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
May 28, 2009 | Marantz SR6001
Burned resistors r319,r320
ampmann,
hi mate, i might be able to help you but i need to know the exact model number and brand of your dvd player.kindly email it to workshop.fungkuei@vanuatu.com.vu
cheers,
markiez23
Jan 15, 2009 | Panasonic Televison & Video
Sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Jan 07, 2009 | Sony KV-27S46 27" TV
Epson stylus photo r320
You may have a problem with the switch panel board. If you disassemble it, you may be able to test the panel by shorting the two connectors to the power button. On the other hand it could be the power supply that is dead on the output side. Both are problems that do occur with R3** series but not that common.
Sep 16, 2008 | Epson Stylus Photo R320 InkJet Printer
Sony PFM-42B1E plazma screen
Does the red standby light flash ?? If so count the flashes and see my error code section.
Jul 05, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
RCA DRC313N DVD Player Logo
24 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
