SOURCE: What type of batteries do I need for a desktop air hockey table?
I don't know which brand you have, but in general you will probably need 2D batteries. I advise you to get 4 or 6 batteries in advanced so you'll have spare ones when needed.
SOURCE: how much electricity do air hockey tables consume?
Most of the modern big tables consume 80 cubicfeet of air flow per minute. I suggest that you call your electricity providerand check how it translates to money. But, in general they do not consume muchelectricity.
SOURCE: How do I clean my air hockey table?
Air hockey tables can be cleaned with isopropyl and paper towels. Make sure not to use too much at once, and then dry it off with the paper towels, so the alcohol will not soak into the table surface. Note that you should not clean the rails as the dirt inside the rail actually prevent the pucks from flying off the table.
SOURCE: Which Air Hockey table should I buy?
If you want an approved
for USAA tournaments then you can check out any of the 8 foot long Dynamo Air
Hockey table, just stay away from the "Hot Flash" series. In the "Hot Flash" Air
Hockey tables the painted rails make the puck fly off a lot, and fluorescent
table-top makes it hard to see the puck. A new Dynamo table price varies from
$1500 to 2500$ so you should take it into consideration.
SOURCE: What's the optimal height of an Air Hockey table?
Theaverage Air Hockey table height is 32 inches, there are also higher tables upto 36 inches if the average 32 inches is not comfortable for you, check outthis sitehttp://www.bmigaming.com/games-sports-airhockey-commercial.htm for more information.
I suggest you to have a
look on some used Air Hockey table on eBay (www.ebay.com).
You can find really great Hockey table
in a very reasonable price and in great shape, I believe you can find a good
one in about 300$-400$.
The Valley-Dynamo
Hot Flash 2 8 Foot Air Hockey Table is considered to be the best Air Hockey
table of all times, this table is the standard table of all the professional
tournament although it's price is a bit price if you want to buy it, something like
4000 dollars.
An air hockey table requires a lot of electricity
in comparison to other electrical devices in your house due to the air inflating
machine. Try turning off the Air Hockey table every time you're done playing
with it to cut on the electrical bill, I've done this mistake of keeping the
table running for nothing on the first month and I've learned my lesson.
You can find Air Hockey tables in both
www.amazon.com and www.ebay.com they got a variety of hockey
tables of the entire major brand. I can tell you that I got my table from http://www.nextag.com/air-hockey-table/compare-html
it a website that help you find the best price in the market and connects you
with the supplier which is closer to your home, I was very satisfied with their
services.
